AtomSoft
Ok im having some trouble but not where you would think...
I want to use interrupt to capture incoming UART data. The issue is the data isnt correct.
example 1: if i send a 0x31(aka 1 key) to the MCU it shows 0x99 as the input.
example 2: if i send a 0x32(aka 2 key) to the MCU it shows 0x9A as the input.
What can be wrong ?
MCU is running at 60Mhz, BAUD RATE is 19200. Help Please.
void InitPLL(void)
PLLCFG=0x44;
PLLCON=0x1;
PLLFEED=0xAA;
PLLFEED=0x55;
APBDIV = 0x01;
while(!(PLLSTAT & 0x400)){} ;
PLLCON=0x3;
PLLFEED=0xAA;
PLLFEED=0x55;
void Init_UART (void)
int Div;
/* Initialize Pin Select Block for Tx and Rx */
PINSEL0=0x5;
/* Enable FIFO's and reset them */
U0FCR=0x7;
/* Set DLAB and word length set to 8bits */
U0LCR = 0x83;
/* Baud rate set to 19200 */
Div = (60000000/16)/19200;
U0DLM = Div/256;
U0DLL = Div %256;
/* Clear DLAB */
U0LCR = 0x03;
U0IER = 0x03; //RDA
//Interrupt Setup
VICIntEnClr = 0xFFFFFFFF; //Disable all interrupts
VICIntSelect = 0x00; //UART0 = IRQ Interrupt
VICVectCntl0 = 0x26; // Vector 0 is for UART0 and is Enabled
VICVectAddr0 = (unsigned long)UART0_ISR; //Prototype address to be called
VICIntEnable = 0x40; //Enable UART0 Interrupt
void UART0_ISR(void)
unsigned char temp = U0RBR;
VICSoftIntClear = 0x40; //Clear Interrupt
VICVectAddr=0xFF;
What can be wrong ?
