looking for datasheet 4digit 7-segment
too fast
Hi there..i am looking for datasheet 4 digit 7-segment SL-104** can't be recognized..its also state TCL-1008-P 94HB.
I dont know weather it is common cathode or common anode..any idea how should i test it.
Test it using +5V and 0V with a 330R resistor, by testing pin by pin you should be able to work out the connections also if its CA or CC.
I know its a pain, but we have to do it sometimes with multiplexed LED's
Take notes as you go, good luck...:)
it is not the single 7segment, but in series 4 digit 7-segment..could we test it using the same methode as single 7-segment?
I'm talking about a 4 digit mux type LED.:)
How many pins are there on the LED edge.?
EDIT:
Is it a display with an ic on the LED pcb.?
it is 10 pin on left edge and 6 pin on right edge...Yup it is display on the LED pcb.
Any have idea when i running 4digit 7-segment on proteus, its display constant value, but after i replace it with single 7-segment its display in blinking..i am getting blur right now.
I have a 4 digit LED display with 16 pins
4 pins for the CA, 7 for segements 'a thru g' and 4 decimal points. some n/c
Are you saying there is an ic on the pcb.?
I think my 7-segment is same as yours...i dont have any reference about the pin, do you have datasheet..or can you tell me which pin is a thru g, decimal point pin, and how to know weather its ca or cc??
p/s:sorry my broken English
hi toofast,
My pins are along the bottom edge of my pcb, its not the same layout as yours.
As I said the only way if you cannot get the datasheet for yours, is to use a 330R resisitor and keep connecting the pins until you work out which pins are which.
Thanks to Eric...i have tried connecting the pin by using multimeter
If you are using a meter on ohms, the forward resistance of the LED segment will be low and the reverse resistance VERY high.
On some meters there is a diode test function.
Where is your location.?
I use multimeter as a source about 4.13V, not on ohm, yup my meter have diode test function...i also have tried on single 7-segment. I realized that my 4digit 7-segment is quite weird, it has 16 pin bottom the edge, from left i assume pin 1, pin 1 and pin 2 function to activate the 7-segment and the rest is for display, the pin is not arrange properly..
p/s: im from Malaysia
I use multimeter as a source about 4.13V, not on ohm...i also have tried on single 7-segment. I realized that my 4digit 7-segment is quite weird, it has 16 pin bottom the edge, from left i assume pin 1, pin 1 and pin 2 function to activate the 7-segment and the rest is for display, the pin is not arrange properly..
All the LED panels I have seen are never connect 1,2 3 etc,:)
If you use a supply of about +5V and a 330R resistor, by using a wire link to 0V on a pin and connecting another pin to +5V via the 330R a LED segement may light up.
Keep changing the wire link and resistor pin, IF its a standard LED panel eventually you should be able to work it out.:)
Its not easy, but I dont know another way if you have no datasheet.
Hello Too_Fast,
Can you post a clear photograph or a drawing of your display? There is a way to figure out which pin is which but it will take a little time to do it.
If you can post a good drawing or photograph, hopefully we can show you exactly what you need to do with the help of diagrams.
Torben
