Logic Analyzer
Hi there
I found a cheap and high speed logic analyzer from Acute Technology (TL2036), but I can't figure out, if it is fast enough for even low-speed circuits. For example the data memory at a 200 MHz timing analysis is 4Kbits per channel if I use all 36 channels.
How do I interpret this result? The sample resolution is 250ps, but how much memory does it require to save one sample? Is it possible to sample like 50 clock pulses on a 20MHz PIC circuit?
The datasheet
https://www.acute.com.tw/software/Spec/esptla2k.pdf
Seem to recall that the clock frequency on a PIC is the oscillator frequency divided by 4.
If this is correct, then the instruction clock frequency on your PIC would be 20 MHz/4, or 5 Mhz.
Maybe you should verify this .....
That's not a lot of memory. It doesn't mention if it does any on the fly compression or not, so otherwise, it's 1 bit, one sample. For simple microcontroller work, 200Mhz is far and away fast enough sampling rate.
If you want more memory you have to jump up to the higher models.
I have the Saleae and it's great. It uses burst mode over USB 2.0, so it can sample its max 26Mhz all day long. Software is nice and clean. I like it.
It's limited, 8 leads, and 26Mhz. I've never had any need to go over that, but if you are trying to directly sample USB or something like that you'll get over. Mostly I use it for debugging interfaces with new IC's. SPI, I2C, One Wire, UART...
As for the memory. I'm usually trying to get a decent sample of data for analysis so I can see what's going on. If you think about it, 2Mhz sampling for 2 seconds is 4Mbits. 4Kbits is such a small sample even at a minor 2Mhz sampling rate it's hardly worth it. I'm assuming they have some kind of compression scheme and they only log sample changes, if that's the case, I have no idea how long you could sample for and it would change depending on your rate of change.
