Hi all ,
I want to use a PC's parallel port to control LM 629's. But the 629 requires more i/o lines than the port can provide . Can i use an intermediate device like the 8255 to communicate . The lm629 requires commands for inititialization and operation. Any suggestions ?
Also another blunder . I ordered the encoders with a 1/4 inch through shaft hole (which i realize is way too small ) . If I connect thro' this shaft hole (1/4" aluminium shaft ) to a gear with an ample sleeve length (overlapping most of the free shaft length) , will it hold without failure or do i have to shift to mild steel . shaft length is about 1" (between encoder and gear face , but a sleeve covers this 1")
Thanks for ur input
