Mattaus
Hi all,
First post...please go easy on me
I wish to build an LED driver based around the LM3410 IC. I have built simple drivers based on this IC in the past, however the circuit I have now is considerably more complicated than I am used to, and before I invest time in determining suitable components, I would like it 'reviewed' to ensure I am the connectivity correct.
Basic specifications and some notes:
Any advice or corrections would be greatly appreciated.
Thanks,
- Matt
- VIN = 3V to 8.4V
- VOUT = 7.5 to 11.5V
- ILED = 1.5A max (PWM dimming used to control the LED strong brightness).
- Configured to work as a SEPIC driver with OVP built in.
- The 3.3V zener diode is there to ensure that the LM3410 IC is receiving a suitable input voltage.
- The two squares with "L" in them are the inductors (I got lazy when I made the components in Eagle)
- The farthest to the right diode (pointing up) and R6 form the OVP circuit.
- The LED's are not actually depicted in the diagram above however they go where I have written "I = 1.5A". They are a string of 3 series connected HB LEDs.
Thanks,
- Matt
