Lm311 - How to use properly
gjpollitt
Hi all
Read a post earlier about LM311 and how he couldnt get the circuit to work, well i have similar prob
Have posted my circuit here
Can anyone tell me why it works fine simulated but when i proto it on the breadboard the output (pin7) is .2 V and doesnt change regardless of the inputs?
i have pins 1 and 4 to gnd, 2 and 3 for inputs, 8 vcc, 5 and 6 tied together and 7 output
Graham
UK
  • compar.zip
Replace R1 with a piece of wire. Don't connect pins 5 and 6 together - just leave them unconnected. The output should switch between 0v and 5v(approx). R7 is unnecessary, and draws about 90ma from your 1.1v supply. What is the source of the 1.1v supply?
The R7 is to load the battery being tested, the source of 1.1v is battery. The circuit is for me to test my batteries to see if they need charging or not.
I will try your ideas when i get home from work later
thanks
cant get it to switch state, the led circuit is fine as can make switch between green and red manually with wire
the lm311 output just wont budge from .2v
could it possibly be that i have blown both chips i have? or is something else missing?
this circuit works fine in simulation but not reality :)
LM311
You are right. In the configuration you are using the 311 is a voltage
sensitive switch. When the voltage you are comparing gets very close to the reference voltage, the output will change.
