LED- Varying Luminescence from Single Power Source
Robo222
How is it possible to create a string of LEDs of varying brightness from one power source? I need to create 4 or 5 different intensities if possible??
The simplest way would be to use resistors of different values.
Using a 555 timer circuit to turn the LEDs on/off at different rates would be another way.
And the voltage divider rule will help in deciding which resistors to use:
Vout = R2 / (R1 + R2) * Vin
You don't use a voltage divider to drive LEDs. Instead you simply limit the current with a series resistor or with a series regulated current source.
