LED flash/sequencer
Mosaic
Hi guys:
Seems like I'd be looking at a project to do some decorative coloured LED sequencing/flashing as a hilite for picture outlines, perhaps legal size or so.
I expect perhaps 16 to 32 LEDS in all.
I'm just looking for some advice or to get pointed in the right direction as to a cost effective approach as this may end up commercial if it's cost effective. Basically I have to do a working prototype and see if it gets accepted.
Perhaps a time based random sequence picker would be nice as well.
My initial thoughts are to use flash 'DT" bit patterns for the sequencing with circular/reversible rrf/rlf commands to get the LEDs moving etc. Coupled with a few PWM rotatable PWM bit patterns to influence LED intensity as an additional effect.
Using regular multiplexing I can see 16 LED's will take 4x4 for 8 bits/pins of control, 36 would be 6x6 @ 12 bits/pins. Hopefully I'd like to use a 3V button cell and do away with LED resistors if that's possible. So an MCU that can run on 3V is needed with a sleep mode for energy savings. Perhaps a single tactile can wake from sleep and put to sleep. The watchdog timer can do double duty by starting a new random sequence every few seconds.
The 3V will likely run 2 LEDs in series. So I wonder if by doing so and placing the 3V Led pairs with max separation on the picture outline (180deg phase shift) I can fudge the control matrix down by half and cut out the limiting resistors at the same time.
Thanks for your suggestions.
You cannot run 2 LEDs in series on 3v.
You are jumping around all over the place.
Settle down to a requirement and use a PIC12F629 if you want to drive a number of LEDs but remember that multiplexing reduces the brightness. You can get 8 LEDs on a PIC12F629 with 12mA through each LED. A PIC16F628 will give a 30 LED display at 12mA.
You can drive 12 with a pic12f629 the pickit1 came with 8 on it but you could solder on the 4 they didn't install and it worked fine.
