LCD Template Code For PIC16F84A (Help)
Peter_wadley
I am trying to use Nigels code for driving an LCD with a PIC16F84a instead of a PIC16F628, which is used in his tutorial...
Since the 84a does not have as many (A) pins I wanted to make the connections like this..
RS (pin4 of LCD) goes to A0
RW (pin5 of LCD) goes to A1
E (pin6 of LCD) goes to A2
and as for the 4 data bus bits..
D4 goes to RB0
D5 goes to RB1
D6 goes to RB2
D7 goes to RB3
Here is the code after I have tried modifed it:
PHP:
;LCD text demo - 4 bit mode
cblock	0x20		;start of general purpose registers
count			;used in looping routines
count1			;used in delay routine
counta			;used in delay routine
countb			;used in delay routine
tmp1			;temporary storage
tmp2
templcd			;temp store for 4 bit mode
templcd2
endc
LCD_PORT Equ	05h
LCD_TRIS Equ	85h
LCD_RS    Equ	0x00 ;RS IS ON RA0
LCD_RW   Equ	0x01 ;RW IS ON RA1
LCD_E     Equ	0x02 ;E IS ON RA2
PORTA	 Equ       0x05
PORTB     Equ       0x06
STATUS   Equ       0x03
Z            Equ       0x02
PCL         Equ       0x02
org	0x0000
Initialise
clrf	count
clrf	PORTA
clrf	PORTB
SetPorts
bsf 	STATUS,5	;select bank 1
movlw	0x00		;make all pins outputs (for portA and portB)
movwf	LCD_TRIS
movwf    0x86
bcf 	STATUS,5	;select bank 0
call	Delay100		;wait for LCD to settle
call	LCD_Init		;setup LCD
clrf	count			;set counter register to zero
Message
movf	count, w		;put counter value in W
call	Text			;get a character from the text table
xorlw	0x00			;is it a zero?
btfsc	STATUS, Z
goto	NextMessage
call	LCD_Char
call	Delay255
incf	count, f
goto	Message
NextMessage
call	LCD_Line2		;move to 2nd row, first column
Message2
call	Text2			;get a character from the text table
btfsc	STATUS, Z
goto	EndMessage
call	LCD_Char
incf	count, f
goto	Message2
EndMessage
Stop		goto	Stop			;endless loop
;Subroutines and text tables
;LCD routines
;Initialise LCD
LCD_Init
movlw	0x20			;Set 4 bit mode
call	LCD_Cmd
movlw	0x28			;Set display shift
call	LCD_Cmd
movlw	0x06			;Set display character mode
call	LCD_Cmd
movlw	0x0d			;Set display on/off and cursor command
call	LCD_Cmd
call	LCD_Clr			;clear display
retlw	0x00
; command set routine
LCD_Cmd
movwf	templcd
swapf	templcd,	w	;send upper nibble
andlw	0x0f			;clear upper 4 bits of W
movwf	LCD_PORT
movwf	PORTB              ;[COLOR="Red"]; Line added by PW - problem?[/COLOR]
bcf	LCD_PORT, LCD_RS	;RS line to 0
call	Pulse_e			;Pulse the E line high
movf	templcd,	w	;send lower nibble
movwf	LCD_PORT
call 	Delay5
retlw	0x00
LCD_CharD	addlw	0x30
LCD_Char
movwf	templcd
movwf	LCD_PORT
bsf	LCD_PORT, LCD_RS	;RS line to 1
movwf	LCD_PORT
call 	Delay5
retlw	0x00
LCD_Line1
movlw	0x80			;move to 1st row, first column
call	LCD_Cmd
retlw	0x00
LCD_Line2
movlw	0xc0			;move to 2nd row, first column
call	LCD_Cmd
retlw	0x00
LCD_Line1W
addlw	0x80			;move to 1st row, column W
call	LCD_Cmd
retlw	0x00
LCD_Line2W
addlw	0xc0			;move to 2nd row, column W
call	LCD_Cmd
retlw	0x00
LCD_CurOn
call	LCD_Cmd
retlw	0x00
LCD_CurOff
movlw	0x0c			;Set display on/off and cursor command
call	LCD_Cmd
retlw	0x00
LCD_Clr
movlw	0x01			;Clear display
call	LCD_Cmd
retlw	0x00
LCD_HEX
movwf	tmp1
swapf	tmp1,	w
andlw	0x0f
call	HEX_Table
call	LCD_Char
movf	tmp1, w
andlw	0x0f
call	HEX_Table
call	LCD_Char
retlw	0x00
Delay255	movlw	0xff		;delay 255 mS
		goto	d0
Delay100	movlw	d'100'		;delay 100mS
		goto	d0
Delay50		movlw	d'50'		;delay 50mS
		goto	d0
Delay20		movlw	d'20'		;delay 20mS
		goto	d0
Delay5		movlw	0x05		;delay 5.000 ms (4 MHz clock)
d0		movwf	count1
d1		movlw	0xC7			;delay 1mS
		movwf	counta
		movlw	0x01
		movwf	countb
Delay_0
		decfsz	counta, f
		goto	$+2
		decfsz	countb, f
		goto	Delay_0
		decfsz	count1	,f
		goto	d1
		retlw	0x00
Pulse_e		bsf	LCD_PORT, LCD_E
		nop
		bcf	LCD_PORT, LCD_E
		retlw	0x00
;end of LCD routines
HEX_Table
addwf   PCL       , f
retlw   0x30
retlw   0x31
retlw   0x32
retlw   0x33
retlw   0x34
retlw   0x35
retlw   0x36
retlw   0x37
retlw   0x38
retlw   0x39
retlw   0x41
retlw   0x42
retlw   0x43
retlw   0x44
retlw   0x45
retlw   0x46
Text		addwf	PCL, f
retlw	'H'
retlw	'e'
retlw	'l'
retlw	'l'
retlw	'o'
retlw	0x00
Text2		addwf   PCL, f
retlw   'R'
retlw   'e'
retlw   'a'
retlw   'd'
retlw   'y'
retlw   '.'
retlw   '.'
retlw   '.'
retlw   0x00
end
Basically nothing happens when this is hooked up :eek:
I have a good understanding of the code but I must have goofed somewhere.. any ideas?
P.W
Edit: Im using MPLAB.
Does the LCD light up or show any evidence that it is receiving power supply? Which LCD are you using? Some time ago I spent weeks debugging the LCD, only to find out in the end that my LCD needs at least 7.5V supply and I was supplying 5V!
Hey Mdanh,
The LCD has no backlit so it doesnt light up
It is 2x16
15pins
HD44780A00 (s)
w/ HD44100H
I am giving it 5v
I have gotten the LCD to work with a very dumbed down piece of code from another website but I prefer code to be laided out in methods such as Nigels so that brings me here..
I dont see in the code where D11-D14 are called can someone point it out?
I think that is probably the problem I am facing.. most likely it is because I am using B ports now.. whereas Nigels tutorial uses just A ports?
Where you have added the movwf PORTB, you should have removed the existing instruction movwf LCD_PORT.
You're sending both data and control signals to LCD_PORT, that is PORTA (LCD_PORT Equ 05h). Replace LCD_PORT with PORTB if you're sending data and with PORTA if you're sending control signals.
General purpose registers start at 0x0C (cblock 0x0C).
I have taken out the four movwf LCD_PORT lines
And have changed the cblock register to 0x0c
So movwf PORTB should be sending the data WITH THE 4bits (D11-D14) such as the 2 words we are trying to send in this asm. correct?
Whereas the LCD_PORT is used to control things such as tell the LCD if we are sending data (RS)? if we are Reading or writing (RW) now about E.. when we pulse it high what is this telling the LCD? From what Ive read when we pulse we are preparing the LCD for a data transmission..
But isnt RS the same thing?
Thanks for your help
PW
On a side note, have you considered using a higher language such as PIC Basic to do the work for you?
Device = 16F877
XTAL = 4
LCD_DTPIN = PORTB.4
LCD_RSPIN = PORTB.2
LCD_ENPIN = PORTB.3
LCD_INTERFACE = 4
LCD_LINES = 2
LCD_TYPE = 0
ALL_DIGITAL = True
Delayms 150
Cls
Main:
    Print At 1,1, "Hello World"
    While 1=1                                ' Loop for ever
    Wend
All written in **broken link removed**
Personally I would suggest moving the LCD entirely to PortB, the tutorial code is designed to easily move between full ports, and just needs the equates changing at the beginning.
What speed is your pic running at? Nigel's routines are designed for 4MHz. If you are running any faster then you will have to change the delay routine.
All written in Proton
Gramo,
Thanks for the suggestion..
Proton seems like a very user friendly and simple program great for people who are after the end result.. a perfectly and simple working LCD for their projects that is easy to debug..
Personally Id rather learn exactly what processes are going on between the controller and LCD.
Its running at 4mhz w/ xtal
Yes I think I am just going to arrange like so..
RB0 = RS
RB1 = RW
RB2 = E
RB3 = D11
RB4 = D12
RB5 = D13
RB6 = D14
The reason I didnt want to do this is because of us Pic Novices favourite thing.. pins which can only be used for input/ can't sink or source..
Which pins must I stay away from? I know RB4 is dangerous 5 too?
Is it fast to use 8bit mode rather then 4bit mode?
From what Ive gathered 4bit sends data out 2 steps where 8bit would send in 1.
PW
All of PortB is fine, it's RA4 you're thinking off that's open collector, which is fine as well - as my tutorial board includes a resistor for that very reason. 8bit mode is slightly faster, but it's not worth it for the extra pins you need - if you use my tutorial code that reads back from the LCD it's very fast anyway, far faster than you can read, or the LCD can actually update.
House0Fwax said:
What was the problem ?
The four occurences of these lines:
movwf LCD_PORT
movwf PORTB
caused the problem.
I added the line 'movwf PORTB' because the 4bits d11-d15 were moved to portB
I didnt take out the line 'LCD_PORT' because I figured that since, in Nigels orginal code, ALL of the LCD leads are attached to PORTA therefore this line wouldnt have any negative ramification on the program... guess not :p
I still dont understand why it would cause the program to stop working entirely.. but its working now so I cant complain!
Ok, the first problem is taken care of - now for the second on! :p
My attempts to drive the LCD with ONLY the B ports have proved unsuccessful..
I have the following wiring:
RB0 = RS
RB1 = RW
RB2 = E
RB3 = D11
RB4 = D12
RB5 = D13
RB6 = D14
All I see is at about the 3rd character space on the first line three horizontal lines and on the character space next to it the cursor is flashing!
Here is the code.. i have gone through it 100 times and it looks perfect to me!
PHP:
cblock    0x0C  ;start of general purpose registers
tmp2
templcd2
endc
LCD_PORT Equ    0x06
LCD_TRIS Equ    0x86
PORTA    Equ    0x05
A_TRIS   Equ    0x85
LCD_RS   Equ    0x00 ;RS IS ON RB0
LCD_RW   Equ    0x01 ;RW IS ON RB1
LCD_E    Equ    0x02 ;E IS ON RB2
STATUS   Equ    0x03
Z        Equ    0x02
PCL      Equ    0x02
org    0x0000
Initialise
clrf    count
clrf    PORTA
clrf    LCD_PORT   ;PortB
SetPorts
movlw   0x00          ;make all pins outputs for LCD
movwf   LCD_TRIS
;STARTING OF OUTPUT
Message
btfsc   STATUS, Z
goto    EndMessage
call    LCD_Char
call    Delay255
incf    count, f
goto    Message
EndMessage
Stop  goto  Stop
;LCD routines
;Initialise LCD
LCD_Init
call    LCD_Cmd
call    LCD_Cmd
call    LCD_Cmd
call    LCD_Cmd
retlw    0x00
LCD_Cmd
movwf    templcd
movwf    LCD_PORT
movwf    LCD_PORT
call     Delay5
retlw    0x00
LCD_Char
movwf    templcd
movwf    LCD_PORT
movwf    LCD_PORT
call     Delay5
retlw    0x00
LCD_Line1
call    LCD_Cmd
retlw    0x00
LCD_Line2
call    LCD_Cmd
retlw    0x00
LCD_Line1W
call    LCD_Cmd
retlw    0x00
LCD_Line2W
call    LCD_Cmd
retlw    0x00
LCD_CurOn
call    LCD_Cmd
retlw    0x00
LCD_CurOff
call    LCD_Cmd
retlw    0x00
LCD_Clr
call    LCD_Cmd
retlw    0x00
LCD_HEX
movwf    tmp1
swapf    tmp1,    w
andlw    0x0f
call     HEX_Table
call     LCD_Char
movf     tmp1, w
andlw    0x0f
call     HEX_Table
call     LCD_Char
retlw    0x00
            goto    d0
            goto    d0
            goto    d0
            goto    d0
d0          movwf    count1
            movwf    counta
            movlw    0x01
            movwf    countb
Delay_0
           decfsz    counta, f
           goto    $+2
           decfsz    countb, f
           goto    Delay_0
           decfsz    count1    ,f
           goto    d1
           retlw    0x00
           nop
           bcf    LCD_PORT, LCD_E
           retlw    0x00
HEX_Table
addwf   PCL       , f
retlw   0x30
retlw   0x31
retlw   0x32
retlw   0x33
retlw   0x34
retlw   0x35
retlw   0x36
retlw   0x37
retlw   0x38
retlw   0x39
retlw   0x41
retlw   0x42
retlw   0x43
retlw   0x44
retlw   0x45
retlw   0x46
Text        addwf    PCL, f
retlw    'H'
retlw    'e'
retlw    'l'
retlw    'l'
retlw    'o'
retlw    0x00
end
RB4 has a 10k resistor going to 5v also.
Anythoughts?... even if its a long shot Id like to hear it!
The code is specifically written to require the data lines to be on RB0-RB3. To make it work the way you have it wired, change the 4 occurrences of andlw 0x0f to andlw 0xf0 in LCD_Cmd and LCD_Chr.
Edit, this isn't going to work as the bits are still in the wrong place. I don't have time now but if your still stuck tomorrow I'll see what I can do.
Whoops, just noticed you have the data lines on RB3-RB6. This is not going to work. You can either change them to be RB4-RB7 or you need to modify the code more.
Is it just me? - you post tutorials on the net, with proven working code and hardware, in use by large numbers of people all over the world. Then someone connects it up differently, blindly bodges about with the code, and wonders why it doesn't work.
This is the LCD equates from the tutorial code, to move it to PortB all you need to do is alter PORTA to PORTB, and TRISA to TRISB - it's that simple. Connect it as shown in the tutorials, alter those two letters - and it works on PortB. Why connect it differently?, if you want it different then write your own code!.
LCD_PORT	Equ	PORTA
LCD_TRIS	Equ	TRISA
LCD_RS		Equ	0x04			;LCD handshake lines
LCD_RW		Equ	0x06
LCD_E		Equ	0x07
