I have a project that I would like to add a LCD display too.
It is an auto antenna selector that use data from radio to select which transistor to short to ground to activate a relay.It has 9 2n4401 trans for this.
It is set up to use 2 different types of radios.What I would like to know is if there is a way to send signal to LCD display that can use radio 1 as on line 1 of display which antenna is in use,,and line 2 of lcd to use information for 2nd radio.
Radio 1 uses the 4028b decoder for its circuit
Radio 2 uses 4 Lm339 comparators for its circuit.
Both band decoders are on there separate pcb and the only thing they share in common is the 9 2n4401 going out to the relay control box.
What I would like to do if it can be done is let 1 radio use Line 1 of LCD other radio Line 2.Right now when I switch radios I have to pull the unit out and unplug 1 and then plug the other one up in its socket.If I have to add a second LCD i guess that what I will do,,but trying all other sources before I do that.
Tim
Tim
