RoveyDoveyGrovey
i bought a lcd with a built in controller i think the model is winstar wh1602b in case that means anything to anybody. i thought i'd start with the basics and hook the lcd up in the way described in the pdf file found in the lcd sticky thread under fundementals.
Anyway i tried entering the code 00001111 whic is supposed to display a flashing cursor, but needless to say im getting nothing. im confident i have set up the circuit as shown, but there are a couple of differences, my lcd has an extra 2 pins K and A, i connected A to 5v and K to 0v and instead of using switchs im using wires that i just plug in and pull out of the breadboard, not ideal i know.
Im also getting a curious thing whereby i connect a negative voltage to the contrast pin and some squares appear but then slowly degrade and disappear, if i increase the voltage they just degrade a bit more slowly.
anyway if you made to the end without falling a sleep, then thank you, i would appreciate a push in the right direction.
