I've read 'sticky'.. ICD2 programmer..
hi all..
i am thinking of making ICD2 inchworm by myself..
i hope if i can get the circuit diagram by myself...
i've read the sticky.. but i got nothing...
i hope.. i may be helped...
regards,
simran..:)
sorry...
i am sorry...
i liked that and without asking from you i should not do that...:o
i'll change now...
Please suggest me the new one similar to that...:)
one more question..
How does ICD (In Circuit Debugger) works?
Also the difference between: Programmer vs. Debugger..
Regards,
simran:)
The programmer mode simply programs, reads or erases the PIC including EEPROM & Config fuses.
The debugger uses special hardware found in many but not all PICs that will let you set breakpoints (stops) and single step through you program. You can view/modify SFRs and RAM. The ICD2 will install a small program in the last 1/4K of Flash memory and often use a byte or two of RAM.
IMHO it's an incredible tool.
Debuggers are becoming standard features in many microcontrollers.
WoW..
That's good.. i think programmers will soon bacome things of the past .. Had the ICD is the ultimate product.. should be recognised by microchip...
Simran..:)
Thanks Bill..
I think i'll have to make thorough study of things that are used with PIC along with this microcontroller...
till then
Thanks Bill..
regards,
simran:)
The ICD2 is a MicroChip product!.
But as MicroChip provide full circuit diagrams and the software for it, it's fairly easy (and much cheaper) to make a compatible clone - like the Inchworm and Inchworm+.
thanks once again...
well.. so much of things are available by microchip.. that's a good thing...
i feel.. i've to put much emphasis on research work of these things because.. it is one of the imortant things to work with...
Thanks..
regards,
simran...
