Is this scope any good?
bitem2k
I want to buy a scope, but I know nothing about them;)
does anyone know if **broken link removed** would be anygood?
many thanks
Im a poor student!:D
I cant afford hundreds of £ for a 'proper' scope.
do you think it might be a reasonable first scope?
Did you read the specs?
Real-time sampling: 75MS/s one channel, 150MS/s using two channels
What crap is that: higher sampling rate with more channels :(
Or it's always 75MS/s per channel
Or it's the other way 150MS/s one channel and 75MS/s two channels
and further
Vertical resolution: 8bits/channel
Is that all :(
Use a PIC and send serial data to the PC and you will have better results!!
Since those guys can't write decent specs I would never buy it !!! :o:o:o
Check the NI Site they have (more or less) cheap USB DAQ pads!
Good, very good stuff...
hi bitem,
The spec looks fine, the 8bit [255 increments] Y axis is a little limited.
The advantage of this type of scope is its small footprint and portability and the fact you can store screen shots.
Also with care it will last a long time.
What's the spec of your PC?
Eric
EDIT:
follow up to hero's Q, what projects do you want to scope??
Well I wouldn't buy it because it doesn't support the operating system I use.
I suppose it's better than no scope at all but it depends on what you want to use it for.
No, you could buy a second hand real scope for less money!.
It's something you buy AS WELL as a real scope, not instead of.
and further
Is that all :(
ericgibbs said:
hi bitem,
You both seem to disagree about the specs.
Would 75ms/s only per channel be bad?
Do you mean something like this device ?
Whats the difference between this and a PC scope?
mcs51mc said:
Off topic : £ what England are you in??
I’m sorry, I have no idea what you mean.
ericgibbs said:
hi bitem,
Im just learning how to program the Pic at the moment, so I want to use peripherals such as the PWM module, and shortly serial transmission, etc.
My pc:
Intel 3.4Ghz processor
2048MB Matched pair Gaming ram
300GB SATAHarddrive
They aren't disagreeing about the scpecs. They're saying different things about different parts of the specification.
ericgibbs iss saying that 8-bit vertical resolution is poor and mcs51mc is saying that the sample rate might go down if you use more channels.
You appear to be getting stressed (this is indicated by your decision to use bold text), there's no need to get stressed, no one's arguing or having a go at you.
I agree, real scope first.
And Ebay seems to have a ton of them in the US. I know there is a UK ebay, I would look on there. You will be able to get a used scope for the same price range, maybe less.
hi bitem,
If you want to examine signals like RS232 serial then the USB scope would easily get the job done.
It would also be OK upto 20mHz[clk] to examine the PIC's PWM output.
Most of the digital voltages will be in the order of 5V and the RS232 say +/-15Vmax.
If you wanted to measure very fast edges/pulses you would get some fall off in performance.
The reason I asked about your PC's spec was just to check that the PC may limit the performance of the USB scope,
the PC spec you have will give no problems.
If you had a steam driven MMX200mHz, running Win98 then this could have given problems.
You can buy S/H 'electronic' scopes, if you decide to go that way, check yellow pages for companies that resell S/H equipment,
also try a local industrial auctioneers.
You can get first class equipment for a good price. Always get a pair of good quality 1/*10 probes.
May I ask which town/county you are in?
Eric
No not getting stressed, I dont know what would give you that idea!:confused:
Just emboldening my responses to more easily differentiate between other peoples quotes and my responses!
HerbertMunch said:
Canterbury, Kent
Hi bitem aka hebertmunch
Reason for asking location was to locate a S/H equipment supplier.
This one is in Bognor Regis
Ask for a catalog.
Eric
HerbertMunch said:
Can someone tellme what the difference between a scope and this is.
thanks
Its for Data Logging from external sensors/sources.[slow rate,Data Acquisition (DAQ)]
Example: Temperature recording, etc.
