circuit975
Hello everyone
I am learning Zener diode but something stuck in my mind
Is this zener diode called a wave shaper? So is this information true or false?
hmm thanks actually what I wanted to ask was exactly this: is this diode question example a wave shaping question example?Not really, it's a crude voltage regulator - however, if you feed it a highish voltage AC signal it will clip the negative side to 0.7V, and the +ve side to 10V - so in that respect it will alter the shape of the signal.
Do you see any wave source in that circuit?is this diode question example a wave shaping question example?
this is exactly the answer I was trying to understand thank you very muchA Zener diode is not typically referred to as a "wave shaper." It is used for voltage regulation and protection in electronic circuits.
does it have to be a wave source to be a wave shaperDo you see any wave source in that circuit?
I think differently. A voltage divider with a 220 ohm load would result in 10V without the Zener thus ...220 + 220 = 440.The circuit is a voltage regulator - as long as the "load" is 1k ohms or more. As current flow through the 220 ohm resistor is 46mA or more, the zener essentially does nothing because, in that case, the voltage drop across the 220ohm resistor is more than 10v and the available voltage for the load is less than 10v so no regulation is possible.
you don't appear to think differently, you appear to think exactly the same but added a refinement for maximum wattage of the zener.I think differently.
iyes, you rounded, if would have rounded, my comment about the Zener doing nothing above "46mA" would have been entirely true - because the Zener does do something between 45mA and 45.45mA.** (I rounded 0.0454545 to 45 mA rather than 46 mA but that's not an issue.)
Hello everyone
Sorry to disagree with your statementyou don't appear to think differently, you appear to think exactly the same but added a refinement for maximum wattage of the zener.
