Is there a simple way to do this push button routine
mastero
Hello all,
My code is
'Definition of Input ports
Symbol sw = PORTB.5  'input
Symbol led = PORTC.5
Symbol led1 = PORTC.2
led = 0
led = 0
k = False
y = 0
x = 0
'********** Main loop ******************
menu:
Gosub check_switch
Goto menu
End
check_switch:
If sw = 0 Then
		k = True
Endif
If sw = 1 Then
	If k = True Then
		If x = 0 Then
			led = 1
				WaitMs 1
			led = 0
			k = False
			y = 0
		Endif
	Endif
Endif
If sw = 0 Then
	If k = True Then
		If x = 0 Then
			y = y + 1
			If y = 10 Then
				led1 = 1
				WaitMs 1
				led1 = 0
				x = 1
			Endif
		Endif
	Endif
Endif
If x = 1 Then
	If sw = 1 Then
		k = False
		y = 0
		x = 0
	Endif
Endif
	Return
Code is for a push button on input which is high always.
When i press the button for less than 5 sec it should light LED on PORTC.5
When i press the button for more than 5 sec it should light LED on PORTC.2
The code works perfectly but is there a simpler way to do it ? to save code space
cheers
Mastero
This may not be correct BASIC syntax but hopefully you'll get the idea it will make sense. Basically, since you're looking for "short" and "long" presses, use a switch state latch bit and simple logic to act only on "new press" and "new release" states. Start a 5 second timer on a "new press" state and toggle your "short" or "long" LEDs according to the timer on a "new release" state.
Good luck. Cheerful regards, Mike
led0 = PORTC.5              '
led1 = PORTC.2              '
swnew = 0                   ' new switch sample
swold = 0                   ' switch state latch
main:
  WaitMs 50                 ' 50-msec sample/debounce interval
  swnew = ~PORTB            ' sample active lo switches
' if new press
  if swnew.5 = 1 and swold.5 = 0 then
    swold.5 = 1             ' update switch state latch
    swtmr = 5000/50         ' start 5 second timer
  endif
' if new release
  if swnew.5 = 0 and swold.5 = 1 then
    swold.5 = 0             ' update switch state latch
    if swtmr > 0 then       ' for "short" press
      led0 = led0 xor 1     '   toggle LED "0" (RC5)
    else                    ' for "long" press
      led1 = led1 xor 1     '   toggle LED "1" (RC2)
    endif                   '
    swtmr = 0               ' reset 5 second timer
  endif                     '
'  5 second timer
  if swtmr > 0 then         ' if timer running
    swtmr = swtmr - 1       ' decrement timer
  endif                     '
  goto main                 ' loop forever
