I work on electronics out of dairy farms … and I have an issue with some milk meters.
Very basic concept (1st model) … donut shaped float with a magnet inside … slides on a stem with a reed switch at bottom and top.
When float reaches top (known quantity of milk) the dump valve opens … then cycle repeats.
For some reason these later models use an MLX90251 in place of a reed switch and I’m starting to see more and more with crook sensors.
Even though they are a very simple device … just a new base (with stem) on its own is over $600 … so replacing a couple of $5 parts still seems reasonable to me … and certainly to the dairy farmers as well.
I’ve researched in the past but came to a dead end … or at least a very expensive solution in buying a genuine programmer … and then trying to work out what to program into them.
Essentially they are a programmable resistor ... so I don't see why I can't cobble something together.
Device overview … https://www.melexis.com/en/product/MLX90251/Programmable-Linear-Hall-Effect-Sensor
Datasheet: https://www.melexis.com/-/media/files/documents/datasheets/mlx90251-datasheet-melexis.pdf
Thanks for any help.
