The 20 awg should handle the current. The 24 is a little small.
How large do the Heat Sinks need to be on the MOSFET?
I wish I had a way to set each MOSFET to run at 200kHz using a 555 timer will be guess work?
There are several online inductor calculators each one gives me a different answer but some are in the same ball park. One calculator says #20 wire it good for 180 watts. I remembered from my experence building coils 40 years ago the more compact the coil is the high the uh value. I have a box full of cardboard coil forms so I will built this.
Inductance 0.05 mH
DC Resistance 0.11 Ohms
Wire Gauge 20 AWG
Wire Diameter 32 mils (1 mil = .001 in)
Coil Length 0.5 in
Coil Inner Diameter 0.63 in
Coil Outer Diameter 0.88 in
Average Turn Diameter 0.71 in
Wire Length 10.81 feet
Copper Weight 0.03 pounds
Turns 58
Levels 3.71
Turns/Level 15.63
