AtomSoft
Of course i am using a 18F1320 and a junebug....
I found code from Here and edited it. It works well but not as expected really. I wanted when i press a button (1 or Vol Up) LED #1 lights and it does but doesnt stay lit for long. The same for button (2 or Vol Down) but for some reason it lights for like 1 sec then turns off. Its supposed to stay ON until a new command is recieved . Any help would be great.
list p=18F1320
include <p18F1320.inc>
; include <Macros.inc> - Dont need
CONFIG OSC = INTIO1, WDT = OFF, LVP = OFF, DEBUG = ON
btDone equ 0x0
btStart equ 0x1
btCommand equ 0x2
cblock 0x00
Time2
BitCount
DeviceCode
CommandCode
IRStatus
Bit
ScratchCode
d1
d2
d3
endc
org 0x0000
goto Init
;* Interrupt Service *
org 0x0008
ISR
bcf LATA, RA0
bcf LATA, RA6
btfsc IRStatus, btDone ;Has a code already been read?
goto ISR_Done
btfsc INTCON2, INTEDG0 ;Check if falling or rising signal
goto Rise
btg INTCON2, INTEDG0
clrf TMR0L ;Reset Timer
movlw b'11000111' ;Enable timer 0, use 8bit counter, use 256 prescaler
movwf T0CON ;Do it
goto ISR_Done
Rise
clrf T0CON ;Disable timer 0
movff TMR0L, Time2 ;Put timer 0 value into storage
nop
GetPulseWidth
movlw 0x11 ;Check for start pulse,
;should be between 0x12 and 0x14
cpfsgt Time2 ;Greater than 0x11?
goto CheckZero
movlw 0x15
cpfslt Time2 ;Less than 0x15?
goto IRError ;Start Bit exceeds tolerance
StartBit ;We have a Start Bit
btfsc IRStatus, btStart ;Check if already set (ERROR)
goto IRError
bsf IRStatus, btStart ;Flag IRStatus
movlw 0x7
movwf BitCount
goto ISR_Done
CheckZero
movlw 0x3 ;Check for zero pulse
;Should be between 0x4 and 0x6
cpfsgt Time2 ;Greater than 0x3?
goto IRError
movlw 0x7
cpfslt Time2 ;Less than 0x7?
goto CheckOne
ZeroBit ;We have a zero bit
btfss IRStatus, btStart ;Check if we have previously had Start Bit
goto IRError
movlw 0x00
movwf Bit
call ProcessBit
goto ISR_Done
CheckOne
movlw 0x8 ;Check for One Pulse
;Should be between 0x9 and 0xB
cpfsgt Time2 ;Greater than 0x8?
goto IRError
movlw 0xC
cpfslt Time2 ;Less than 0xC
goto IRError
OneBit ;We have a One bit
goto IRError
movlw 0x1
movwf Bit
call ProcessBit
goto ISR_Done
IRError
call ClearVariables
bcf INTCON2, INTEDG0 ; Interrupt on falling edge
ISR_Done
clrf LATA
bcf INTCON, INT0IF
retfie FAST
;* End of Interrupt Service *
;* Routines *
ProcessBit
btfss Bit,0 ;Check if bit set
goto WriteZero
WriteOne
bsf ScratchCode, 0x7
goto RotateRight
WriteZero
bcf ScratchCode, 0x7
RotateRight
rrncf ScratchCode
decfsz BitCount
return
WhichCode
btfss IRStatus, btCommand
goto CommandCodeDone
DeviceCodeDone
rrncf ScratchCode ;a couple of more rotations
rrncf ScratchCode
movff ScratchCode, DeviceCode
bsf IRStatus, btDone
return
CommandCodeDone
movff ScratchCode, CommandCode
bsf IRStatus, btCommand
movlw 0x5
movwf BitCount
clrf ScratchCode
return
ClearVariables
clrf IRStatus
clrf DeviceCode
clrf CommandCode
clrf ScratchCode
return
;* End of Routines *
Init
call ClearVariables
movlw 0x72 ; 8MHz clock select
movwf OSCCON
bcf ADCON1, PCFG0 ; Set RA0 as digital
bsf TRISB, RB0 ; Make RB0 Input
bsf TRISB, RB2 ; Make RB5 Input
bcf INTCON2, RBPU
bsf ADCON1, PCFG4 ; Make RB0 digital
movlw b'10111000'
movwf TRISA
bcf LATA, RA0
bcf LATA, RA6
clrf T0CON
InitISR
movlw 0x13
sublw 0x13
bsf INTCON, INT0IE ; Enable INT0 interrupt
bcf RCON, IPEN ; Disable priority interrupts
bcf INTCON, INT0IF ; Clear INT0 flag - This stumped me at first
bcf INTCON, PEIE ; Disable peripheral interrupts
bsf INTCON, GIE ; Enable global Interrupt
Main
bsf LATA, RA0 ;Light LED 1
bcf LATA, RA6
;BCF LATA, RA1
;BCF LATA, RA2
btfss IRStatus, btDone
goto Main
bcf LATA, RA0 ;Light LED 2
BSF LATA, RA6
[b]
WaitForRB2
; btfsc PORTB, RB2
;goto WaitForRB2
;AtomSoft Code
MOVLW 0x10 ;My Vol Device
CPFSEQ DeviceCode
goto NumCode
goto IsOurs
NumCode MOVLW 0x0D ;My Number Device
CPFSEQ DeviceCode
goto NotOurs
goto IsOurs2
NotOurs
call ClearVariables
goto Main
IsOurs
MOVLW 0x12 ;My Volume Up Button
CPFSEQ CommandCode
goto Check2 ;Not Volume Up
goto VolUp
Check2
MOVLW 0x13 ;Volume Down
CPFSEQ CommandCode
goto NotOurs ;Not in our commands so clear all
goto VolDwn
VolUp
No1 call Delay
BCF LATA, RA1
BSF LATA, RA2 ;High on RA2 my TOP LED
call Delay
call Delay
call Delay
goto NotOurs
VolDwn
No2 call Delay
BCF LATA, RA2
BSF LATA, RA1 ;High on RA1 my BOTTOM LED
call Delay
call Delay
call Delay
goto NotOurs
IsOurs2
MOVLW 0x00 ;My # 1 button
CPFSEQ CommandCode
goto CheckN2
goto No1
CheckN2
MOVLW 0x01 ;My # 1 button
CPFSEQ CommandCode
goto NotOurs
goto No2
Delay
movlw 0x07
movwf d1
movlw 0x2F
movwf d2
movlw 0x03
movwf d3
Delay_0
decfsz d1, f
bra $+6
decfsz d2, f
bra $+6
decfsz d3, f
goto Delay_0
bra $+2
bra $+2
bra $+2
return
end
[/b]
