gramo
Just playing around with IR, and before I go off and order these AND gates, just wanted to be sure everything will work
PORTC.2 has a constant 38Khz PWM with a 50% duty cycle. The other input of the AND gate is connected to the UART TX of the PIC.
The idea is to use the and gate to switch the modulated signal (38Khz) on/off in synch with the UART signals, to the IR Emitter LED. You now have a 38Khz modulated UART IR signal...
The receiver’s output should look just like that of the UART, as it will demodulate the 38Khz signal too logic voltages (normal UART), and that will be connected to the RX of the receiver PIC
Here's the transmitter;
And the receiver;
The modulated UART signal might contain small errors, as the AND gate can't control the rise/fall conditions of the PWM input. Sometimes it might be one pulse out, others right on. With this in mind, I would start at around 300 baud, and trial it upward from there.
Should be noted that the 74HC08 has rise/fall times of ~33nS @ 5V, and can source/sink upto 25mA
And the receiver;
