interrupts introduction
butters
hey all, im currently doing a project which involves interrupts.. but whats with high priority and low priority...
i know theres two interrupt vectors... 0x0008 and 0x0018..
care to explain more...
thanks! :)
Pommie
Most Helpful Member
If you don't enable prioritised interrupts (IPEN=0, the default) then all interrupts go to the vector at 0x08. If you enable priorities (IPEN=1) then any interrupts with its priority bit set will go to 0x08 but all other interrupts will go to 0x18. High priority interrupts will interrupt a low priority ISR.
Check any 18 series data sheet for a better explanation.
Lighty
Don't laugh, but what / how does an Interupt do/ work?
An input that will action no matter where in the "program" the PIC is busy processing?
bananasiong
LOL Mike :D
Lighty, basically yes. During the normal operation of the microcontroller, if the interrupt is enabled and interrupt has occured, the interrupt will be serviced, no matter where is it. Interrupt can also be used to wake up the microcontroller from sleep.
wael_sal
Good Day;
My question about interrupts : when u have many interrupts with same priority, if an interrupt occurs during servicing another one, will the PICmiro continue the current one and then service the other ?
Best Regards
Wael
blueroomelectronics
On a 14bit core (16F, some 12F) an interrupt will turn off the GIE (Global Interrupt Enable) bit so no other interrupts will be serviced till a RETFIE (automatically sets the GIE bit)
Interrupts flags set while GIE was disabled will then be serviced.
Now I'm rusty on the 18F as they have two levels. I'm not sure if a high level interrupt will be called while servicing a low level one.
wael_sal
thanks for your reply, but when u have many interrupts with same priority, I have more than one routine at high level interrupt, Is this will cause any conflict between these routines?
Regards
Wond3rboy
Yeh what are you doing which requries so many interrupts?
In PIC18 there are only 2 types of interrupt priorities. As far as the prioritizing individual interrupts is concerned then it depends on the sequence in which you check the flags.When an interrupt occurs then it just gose to the corresponding vector address for High and Low priority interrupt respectively.
