interfacing eeprom with pic16f767
frubo
Im trying to interface 2 of my 24AA1025 eeproms to my pic16f767. Ive never done anything like this and I am confused at where to begin. I read through the datasheet on the pic16f767 where it describes how to transmit data using built in USART Synchronous Master Mode. It says it works for serial eeproms so I assumed thats what I wanted (maybe not). The problem is when I look at the data sheet for the eeprom it goes into things like start/stop, acknowledging, and clock cycles. These things arent described in the pic datasheet. What do I do?
Your eeprom is an I²C device. You need a pic that has hardware I²C or bitbang it. I have posted code to access serial eeproms somewhere on here. Have a search and see if it helps.
I did some research and put bits and pieces of code together but I am having a difficuilt time debugging it. It simply writes a single byte (0x05) to eeprom and reads it back displaying it on PORTA leds. Despite writing 0x05 to the eeprom I always get 0x01 back. I am not sure whether it is my read or write. Also I have pull up resistors on SCL and SDA (5k ohm).
	list             p=16f767
	#include	<P16F767.inc>
d1		equ		20h
d2		equ		21h
d3		equ		22h
	org		0x0000
	; init
	bcf	STATUS, RP1
	bcf	STATUS, RP0    ;bank 0
	clrf	PORTA
	bsf	STATUS, RP0      ;bank 1
	movlw	62h   	; 4mhz clk
	movwf	OSCCON
	movlw 	0Fh 	; Configure all pins
	movwf	ADCON1 	; as digital
	movlw 	00h 	; all output on portA
	movwf 	TRISA
	bsf	TRISC,3		; set as input (SCL)
	bsf	TRISC,4		; set as input (SDA)
	bcf 	STATUS, RP0 	; bank 0
	movlw	28h
	movwf	SSPCON      ; enable MSSP and stuff
	bsf	STATUS, RP0 ; bank 1
	movlw	09h
	movwf	SSPADD	; 100khz
	; write byte
	call	START
	movlw	b'10100000'       ; control bits (write mode)
	call	SENDBYTE
	movlw	00h                  ; address 0x00
	call	SENDBYTE
	call	SENDBYTE
	movlw	b'00000101'        ; send 0x05
	call	SENDBYTE
	call	STOP
        ; buncha delays just in case, let the eeprom do its thing
	movlw	0ffh
	call	DELAY
	movlw	0ffh
	call	DELAY
	movlw	0ffh
	call	DELAY
	movlw	0ffh
	call	DELAY
	movlw	0ffh
	call	DELAY
	clrw
	; read byte
	call	START
	movlw	b'10100000'        ; write mode first to set current read address
	call	SENDBYTE
	movlw	00h
	call	SENDBYTE
	movlw	00h
	call	SENDBYTE
	call	RESTART
	movlw	b'10100001'            ; control bits (read mode)
	call	SENDBYTE
	call	READBYTE                      ; byte put into w register
	movwf	PORTA                   ; display output
	bsf SSPCON2, ACKDT                ; no acknowledge
	bsf SSPCON2, ACKEN
	call	STOP
LOOP_FOREVER
	goto	LOOP_FOREVER
;	START
START
	bsf SSPCON2,SEN
	call	WAIT
	return
;	WAITSSP
WAIT
	btfsc	SSPSTAT,2
	goto	WAIT
	bcf 	STATUS, RP0 	; Bank0
	return
;	STOP
STOP
	bsf SSPCON2,PEN
	call	WAIT
	return
;	RESTART
RESTART
	bsf SSPCON2,RSEN
	call	WAIT
	return
;	SENDBYTE
SENDBYTE
	movwf	SSPBUF
	call	WAIT
	btfsc	SSPCON2, ACKSTAT		; wait for acknowledge
	goto	$-1
	return
;	READBYTE
READBYTE
	bsf	SSPCON2,RCEN
	call	WAIT
	movf	SSPBUF,0
	return
;	DELAY ROUTINE	delays n milliseconds
DELAY
	movwf	d3
DELAY_1
			;993 cycles
	movlw	0xC6
	movwf	d1
	movlw	0x01
	movwf	d2
DELAY_0
	decfsz	d1, f
	goto	$+2
	decfsz	d2, f
	goto	DELAY_0
	decfsz	d3, f
	goto	DELAY_1
	return
	END
You can't just test bit 2 of SSPSTAT. You need to test the individual bits or the SSP interrupt flag.
This is how I do it in my code,
I2cSendStart	movlw	1<<SEN
		goto	I2cSendBit
I2cSendStop	movlw	1<<PEN
		goto	I2cSendBit
I2cSendReStart	movlw	1<<RSEN
I2cSendBit	bsf	STATUS,RP0
		iorwf	SSPCON2,F
		bcf	STATUS,RP0
I2cWaitSSP	btfss	PIR1,SSPIF
		goto	I2cWaitSSP
		bcf	PIR1,SSPIF
		return
HTH
yay I got it working. I had already tried what you just posted and it didnt work but that was because my banks were screwed up. I fixed both of those things though. Thanks for the help. Ive gotta start checking those MPLAB messages 'register not in bank 0' more often, that usually seems to be my problem =/
Good to hear you got it working. Good luck with the rest of your project.
