Hello everyone, First post so take it easy on me
Anyway a little background I'm in the heating, air conditioning, refrigeration, and building control field. I have the need to monitor the temperatures in approximately 35 walk in coolers using are building managment system. I could do this using 35 analog inputs on a few controllers but that get real expensive fast.
So what I need is a device that I can connect multiple sensors to one input on the controller, a multiplexer.
I will use a analog output from my controller controlled through programming to output a voltage from 2 to 10 volts DC. For each different voltage increment I close a relay to connect one of the sensors to the input on the controller.
So basically what I need is a circuit will close a relay with a certain voltage.
For example:
2.5 volts output closes relay 1
3 volts output closes relay 2
3.5 volts output closes relay 3
etc ...
9.5 volts output closes relay 15
10 volts output closes relay 16
Well hopefully this is about as clear as mud
I don't know a whole lot about electronics I do know the basics, but I want to learn.
Thanks in advance,
For example:
etc ...
Thanks in advance,
