Hi
I need a circuit to store a voltage for an indefinite length of time.
The voltage is basically the dc voltage drop across a load resistor.
Some requirements:
1. The voltage range is 10mv to 2.0v dc and it will orginate via a closed
relay contact of a de-energized relay.
2. The relay is push button operated and normally de-energized.
3. The circuit will need to sample the voltage while the relay is de-energized,
then store (hold) the voltage when the relay is energized.
4. The circuit output (voltage sampled) should be uninterrupted during contact transition
from open to closed. or closed to open.
5. The circuit output will be read by a DPM.
(I know there are DPM's with display hold capability, but I don't want this to be a DPM requirement).
I don't have a circuit design yet but believe this requires an infinite hold sample-and-hold circut. Hoping there is an IC for this...
BTW...I'm not using Microcontroller, using cmos devices...
I'm looking for suggestions...
Any suggestions?
Thanks!
eT
Some requirements:
Any suggestions?
Thanks!
eT
