I was thinking about in the possibility to know if a car's ignition coil can work using pulsed alternating current?
The idea is to switch off the power when the AC Voltage is at its maximum positive value. If I use a high frequency than 50 Hz (For example 500 Hertz) it should be very similar to pulsed DC.
If this is not possible with ignition coil, could it be possible with a flyback?
