I2C Master Slave Read data from slave
SneaKSz
Hello all
I'm experiencing problems with receiving data from my slave. The slave knows its addressed and sets its data into SSPBUF. The data also clocks out, but when I read the SSPBUF in the master, it's not the value I send over I2C.
This is the picture of the master receiving data ( address = 0x08, the +1 for reading, data = 0xAA).
https://img191.imageshack.us/i/masterreadslave0xaa.png/
This is the routine :
					SendStart(); // send S
					Delay10TCY();//
					SendByte2(0x08+1); // Address READ
					Delay10TCYx(10);//
					SSPCON2bits.RCEN=1;
					Delay10TCYx(10);//
					SSPFlag();
					Delay10TCY();
			//		test=ReadI2C();
					while(SSPSTATbits.BF == 0);
					Delay10TCY();
					Nack();
					Delay10TCY();
					SendStop();
					Delay10TCY();
					Delay10TCY();
					SSPCON2bits.RCEN=0;
				//	Delay10KTCYx(1);//
					Delay10TCY();
					errorV= SSPBUF;// put the SSPBUF in a char
void SendStart(){
SSPCON2bits.SEN=1;
SSPFlag();
void SendStop(){
SSPCON2bits.PEN=1; // P activeren
SSPFlag();
void Nack(){
SSPCON2bits.ACKEN=1;
SSPCON2bits.ACKDT=1;
void SSPFlag() {
while(PIR1bits.SSPIF==0); // wait until sent
PIR1bits.SSPIF=0; // set low
The problem is that I can't send a NACK and a STOP bit. Someone sees the wrong sequence in my code?
Fixed : The problem was there is a busbuffer and opto coupler between the master & slave. A resistor was chosen badly and the LOW level was 4.5V, by choosing a correct resistor, the low level went to 0.5V and the master received a NACK.
