I NEED HELP
HAMZAZAYYAD
hi
i need help
linker
CODEPAGE NAME=vectors START=0x0 END=0x1F PROTECTED
CODEPAGE NAME=page START=0x20 END=0x3FF
when i uses a sub program only, no errors
but when i uses more than one sub program ,this error apear
Copyright (c) 2005 Microchip Technology Inc.
Error - section 'INT_VECTOR' can not fit the absolute section. Section 'INT_VECTOR' start=0x00000000, length=0x0000005a
Errors : 1
BUILD FAILED: Mon Jun 06 14:59:42 2005
whats wrong??
my program USES PIC16F84A WITH ASSEMBLY ,MPLAB
SUB PROGRAM
RETURN
SUB PROGRAM1
RETURN
SUB PROGRAM2
RETURN
MAIN CODE
start
call SUB PROGRAM1
call SUB PROGRAM2
mhh i think
its the limit stack size you have problem with..
an sub is only used when you want be able to retun....
and you can only use 1 at a time...
you will need to think about an solution...
for example
Do
if x=x go sub number1
if x=x go sub number2
loop
sub number1
return
sub number2
return
if i was you and if your program isn't really big,
just copy the code or make an sub with both integrated (that means all the code dubble)
else get an proper device 16F877a
TKs
