I dont know much about resistors
eggi
I am gonna try and build this **broken link removed**
but have a few questions about resistors:
- how important is it that the watt values match? can I use a 50w where Wallins use a 20w? or a 0.5 watt where he uses a 0.25watt?
- i was thinking buying a 1% resistor lot on ebay, can I use these where he uses 5% resistors?
"Soundwaves are the best waves"
Yes, You may always replace a resistor with one that has a higher watt rating. It's the power the resistor can handle, putting in a higher-spec one is allright, it'll only be bigger
Again yes, This percentage is the precision of the resistor. Putting in a more precise resistor is obviously ok. They'll probabely cost a bit more then 5% ones
yes, on both counts... the wattage of a resistor is how much power it can dissipate - in other words how well it resists heating up. using a 50w instead of a 20w means it'll stay cooler if you were to push it to the limits.
and using a 1% accuracy resistor instead of a 5% is fine too, if anything, it's better... all that means is that the resistors are guaranteed to be a lot closer to their rated values.
One point to bear in mind with really high wattage resistors, they are usually specified as mounted on heatsinks - large ones!. Without a heatsink you need to derate them considerably - so if it's got mounting holes, it may well need a heatsink.
which makes using a 50w instead of a 20w even better in this case. you can probably get away with NO heatsink on a 50W resistor if it's only dealing with 20 watts of power or less, saving you the hassle of mounting a heatsink, etc.
however, make sure you can FIT a 50w resistor into your project. they aren't small, by any stretch of the imagination. The ones I've been using at work are a couple inches long, about as big around as your finger, with big mounting lugs, and a bunch of cooling fins.
if you were to build the project in an aluminum (or other metal) enclosure you could simply drill a couple holes and bolt them to it, that should be a more than adequate heatsink since you're only running them at up to 40% of their rated capacity.
Great, thanks, this was what I thought too, but I wanted to be sure.
One more thing, whats the difference between a SPDT and a DPDT toggle switch? Wallins uses DPDT switches, but on some webshops they only have the SPDT switches, but Im not sure I can use them.
SPDT - single pole double throw - 1 input switched between 2 outputs
DPDT - same as above, but has 2 SPDT operated by the same switch. u can use a DPDT if u cant get a SPDT but no the other way round
Wallins indicates that the 20 w resistor should be non-inductive. Substituting with common wirewound power resistors may add a bit of inductance. At audio frequencies the effect may be trivial though in a test fixture you may want to limit any sources of potential error.
Just to satisfy my curiosity I wanted to see what impact a small amount of inductance might have. I looked at a table and saw that a 5/8" diameter coil (air) with 10 TPI has an inductance of 1.7 microhenries. That might represent the inductance in a 50 w resistor. I also thought that if the inductive reactance were 10% of the resistor value that might be significant given that it is a test fixture - that's 0.8 ohms. At 10 kHz you'd need an inductor with about 13 microhenries to get 0.8 ohms. All of this presumes that my hurry-up math is correct. Where I come out in all this is that using a wirewound resistor may impact things so be ware. The result would be a load that changes slightly with frequency.
That should do perfectly...
It's non-inductive (NH) and according to the graphic's it should be able to take care of 20W without heatsink...
Take a closer look at the power derating graph. The vertical axis is percent of rated power, not watts. The NH50 is rated at 40% (20 watts) with no heatsink to 25C, and goes downhill above that temperature. I would mount it on something that can radiate a little more heat.
