HV transformer
chris54
I am looking for a source of a HV transformer. I would often deal with peter Dahl but since he has passed away harbash electronics has taken over. And the HV transformer is currently unavailable. It is a HV transformer for an HF amp. An old Alpha 76a.
Does any body know how or who I could get one from. Thanks
Do you know what the specifications are for the transformer?
Is there a problem with your old one?
Have you tried any local transformer winders in your area?
I'd have thought given the spec they could make one for you or repair a defective one...
Thats what I was looking for but do not know. Do I mearly do a local search or can you recommend one. Secondary voltage is below what it should be.
Chris...
I'm from the other side of thepond...so cant help you with local knowledge. Just thought I'd throw some ideas at ya..:D
Which secondary voltage is low?
Have you tried disconnecting all from the transformer and measure each winding?
It could be that you have an overload on a circuit?
Chris - you may have already tried posting on QRZ.COM. I used to read thru postings on an AM forum or two - lots of guys there build their own gear and use high voltage supplies. Now and then I'll see stuff like this at hamfests. Not sure if you need just one or are looking for a source for more than one. Look in the back of QST or CQ magazine - again, something you may have already considered. Not sure if you are a licensed/active amateur or not.
Unfortunately I tossed a few transformers out that might have fit your needs. Their condition was unknown to me and it was likely that they were discards - which would explain why I had them in the first place.
