How to use PIc to control a motor?
tmtyen
Hi guys!
i like to control a stepper motor using Pic16 Microcontroller by PWM technique, can you please help me?
1. Which program languages should i use? easy one i'm a beginner.
2. Which Pic16 is the best to use?
do know any useful link?
thank you very much.
tmt
hey, first question i will probably get flamed for but i find ASM easyest to use, mainly cuas its risc, u just have 36 (ish) instructions, and once u get over some conceptual difficulties it makes life much simpler as long as u don't have to do not arithmetic maths.
16 series PIC realy depends on the rest of ur application some have PWM modules built in, which would make coding ur project a snip but might be un-necisserry if all the chip has to do is make PWM (555 would be easyest!).
In short could u say a little more about ur project, or just pic a 16 with a PWM and the datasheet tells u how to use it in ASM
Use a PIC16F873-20Mhz with two PWM channels to control the current to the two phases of the motors. The PWM frequency is just under 20Khz. Couple the PIC to a pair of H-bridge circuits with current sensing resistors at the bottom of the bridge. Amplify the voltage from current sense resistors using op-amps and feed them into the analog-to-digital converter inputs of the PIC.
There is a newer pin compatible version. It's the PIC18F242-40Mhz. The advantage is that this PIC has a hardware multiply that is needed to calculate the PWM value corresponding to the error in the current level.
There is an application note at Microchip for a DC motor application but this will give you some idea on how to do it with steppers.
I also agree that assembly would be best, specially for the timing critical portion of the software that controls the current.
