How to read values from ATmega328P?
henkoegema
I have compiled and flashed (successfully) following program to the atmega328P (connected to a raspberry pi, MOSI-MISO-....).
This program reads a voltage on pin A0
const int analogInPin = A0;
float sensorValue = 0;
void setup(){
Serial.begin(9600);
void loop() {
sensorValue = analogRead(analogInPin);
Serial.print(¨Voltage Output = ");
Serial.print(sensorValue*5/1023);
Serial.println(" ");
delay(100);
I only use the command line in the raspberry pi. (no GUI)
When I've flashed the program I get the command prompt back. So far, so good.
Q: How do I read the values of the program in the atmega328p back into my raspberry pi? :(
(How I flashed it: $avrdude -p m328p -c gpio -e -U flash:w:build-cli/Arduino.hex)
I don't know or use the Pi
Your serial terminal will display the reading as you have set it up above so you will have to get that serial output read by the Pi
It's easy as
cat /dev/ttyS0
the last part needs to be where your arduino is the com port you have it on to program
