How to program a PIC
cardine
I have a big and frustrating problem, I have a PIC18F1320, a JDM programmer, MPLAB, and this code from Junebug
But I don't konow how to compile it into a hex file that I can write with icprog
#include <p18f1320.h>
#pragma config WDT = OFF, LVP = OFF, OSC = INTIO2
#define ServoPin LATBbits.LATB3
#define ServoTris TRISBbits.TRISB3
void main(void){
int ServoPos;
    OSCCON=0x70;                //Osc=8MHz
    ADCON0=0b00000101;          //A2D on and select AN1
    ADCON1=0x7d;                //A1 = analogue
    ADCON2=0b10110101;          //Right justify - Fosc/16
    ServoTris=0;                //make servo pin output
    ServoPin=0;                 //Servo output off
    CCP1CON=0b00001011;         //Special event trigger
    T1CON=0b10010001;           //Timer 1 on with Pre=2
    ServoPos=1500;              //set servo to mid position
    CCPR1=ServoPos;             //set CCP initial value
    while(1){
        while(!PIR1bits.CCP1IF);    //wait for CCP interrupt bit
        ServoPin=0;                 //end pulse
        CCPR1=20000-ServoPos;       //Off time = 20mS - Servo Time
        PIR1bits.CCP1IF=0;          //clear int flag
        ADCON0bits.GO=1;            //start conversion
        while(ADCON0bits.GO);       //Wait for it to complete
        ServoPos=ADRES+1000;        //Pos will be 1mS to 2.023mS
        while(!PIR1bits.CCP1IF);    //wait for int flag
        ServoPin=1;                 //start pulse
        CCPR1=ServoPos;             //Servo time in uS
Looks like my Junebug servo code.
Start a project in MPLAB with the project wizard.
Select 18F1320 and C18.
Add a file called somert.c to the project and copy the above code into it.
Press F10.
Edit, you add the file after the project wizard has completed. Look under menu Project->Add new file.
HTH,
I didn't find anywhere somert.c so i created a file with that name. When I pres F10 this error shows
Debug build of project `C:\Documents and Settings\bla\My Documents\sw.mcp' started.
Language tool versions: mpasmwin.exe v5.31, mplink.exe v4.31, mcc18.exe v3.31
Preprocessor symbol `__DEBUG' is defined.
Mon Jul 27 17:31:36 2009
Make: The target "C:\Documents and Settings\bla\My Documents\somert.o" is out of date.
Executing: "C:\MCC18\bin\mcc18.exe" -p=18F1320 "C:\Program Files\Microchip\MPASM Suite\Template\Code\somert.c" -fo="somert.o" -D__DEBUG -Ou- -Ot- -Ob- -Op- -Or- -Od- -Opa-
C:\Program Files\Microchip\MPASM Suite\Template\Code\somert.c:1:Error [1027] unable to locate 'p18f1320.h'
Halting build on first failure as requested.
Debug build of project `C:\Documents and Settings\bla\My Documents\sw.mcp' failed.
Mon Jul 27 17:31:37 2009
BUILD FAILED
Try downloading and installing the latest version of C18. Your paths are not setup correctly and installing the latest version should fix that.
I have installed MPLAB IDE 8.33 and C18 and now I get the same error
Debug build of project `C:\Documents and Settings\bla\My Documents\4.mcp' started.
Mon Jul 27 18:40:26 2009
Executing: "C:\MCC18\bin\mcc18.exe" -p=18F1320 "C:\Program Files\Microchip\MPASM Suite\somert.c" -fo="somert.o" -D__DEBUG -Ou- -Ot- -Ob- -Op- -Or- -Od- -Opa-
C:\Program Files\Microchip\MPASM Suite\somert.c:1:Error [1027] unable to locate 'p18f1320.h'
Debug build of project `C:\Documents and Settings\bla\My Documents\4.mcp' failed.
Mon Jul 27 18:40:28 2009
BUILD FAILED
I installed all the programs three time and it is the same
What does it mean that
somert.o is out of date.
could not find file c018i.o
Debug build of project `C:\777.mcp' started.
Mon Jul 27 21:05:14 2009
Make: The target "C:\somert.o" is out of date.
Executing: "C:\MCC18\bin\mcc18.exe" -p=18F1320 "somert.c" -fo="somert.o" -D__DEBUG -Ou- -Ot- -Ob- -Op- -Or- -Od- -Opa-
Make: The target "C:\777.cof" is out of date.
Executing: "C:\MCC18\bin\mplink.exe" /p18F1320 "somert.o" /u_CRUNTIME /u_DEBUG /z__MPLAB_BUILD=1 /z__MPLAB_DEBUG=1 /o"777.cof" /M"777.map" /W
MPLINK 4.31, Linker
Copyright (c) 2009 Microchip Technology Inc.
Error - could not find file 'c018i.o'.
Errors : 1
Link step failed.
Debug build of project `C:\777.mcp' failed.
Mon Jul 27 21:05:16 2009
BUILD FAILED
