Hello again,
Sometimes the output impedance will be specified simply to protect the amplifier or for other reasons. For example, if they spec 8 ohms then the output stage is designed to handle 8 ohms and not 4 ohms as that may harm the output stage, and not 16 ohms as that may mean higher distortion. When it comes to audio power amps i try to match the speaker to the recommended value for that amp.
Also, the internal design will always have a voltage limited power supply and using a speaker that is too high in impedance will not allow full output power for that amp.
