How to measure current using ADC?
StupidDum
Is there ADC for current measurement?
Or need external resistor circuitry to somehow convert current to voltage?
Thanks to an expert, Nigel.
I think he just taught me that it can be done by first converting the current to voltage through an op-amp circuitry.
Please correct me if I'm wrong. Need advice, please?
You simply measure the voltage drop across a resistor in series with the load - simple ohms law, a 1 ohm resistor will drop 1V for every amp of current.
As you probably can't afford to lose 5V off your supply rail, it's usual to use a smaller resistor and amplify the voltage drop with an opamp - this also allows you to reference the voltage to 0V (by using a differential opamp circuit).
Thanks! Now i've got rough idea of how things are done.
Now I am having difficulties in selecting components.
Suppose I use 5V supply, which Op-Amp and ADC is suitable??
There are too many op-amp, and there are quite a lot that can fit into this application as well. Which type of op-amp is more appropriate?
what are you thinking of trying to measure??
am i correct that you are not trying to measure 5A of current ?
hopefully ?
i have used a 1 ohm resistor on many occasions to measure current -in the 0 to 200mA range.
if you set your reference on the adc correctly To 1/2 your estimated maximum input Voltage .you should be fine.. :D
what i am really trying to say is you should study the adc that you intend to use.. becaust there is a minimum voltage that can be converted on all ADC's .
dont quote me on this but 19 mV comes to mind on the 0804 adc
this means that 0 to 18 mV ouputs a 00000000 on the 0804
and 19 mV to 37mV or so produces a 00000001 ..and so on
anyway check the LSB voltage this will give ya an idea of what ya can expect..
the current input range is from 0 - 20mA.
The thing bothering me now is, I have freedom to use any ADC and op-amp, but I have no idea exactly which one the be used.
I need an ADC with SPI interface , in PDIP package. Do you have any ADC in your mind now?
the MPC 3004
