How to make a Momentary switch have multiple functions
If anyone can put a .hex
Grateful for your response in advance!
Download MPASM and you can do it yourself.
'635 and '200 v2 HEX files attached. They were assembled using the default radix.
  • 635v2.HEX
  • 200v2.HEX
I understand the little pic.
I tried it with MPLAB IDE v8.88 but we failed to do .hex .
Many thanks a lot for the .hex .
Do I Fuse bit set?
You would want MCLRE, WDT and CP all off
.asm V2 to write the 10f200 :
"'__CONFIG _MCLRE_OFF & _CP_OFF & _WDT_OFF"
I wonder if I'm set up right.
This is picture 1
.asm V2 to write the 12F635 :
"__config _FCMEN_OFF&_IESO_OFF&_MCLRE_OFF&_WDT_OFF&_INTRC_OSC_NOCLKOUT"
This is picture 2
Hello fellow electronics, would it be possible to modify Mike's code to add an acc relay? if you press one time acc comes on if you press second time acc/on is turned on.
I would be very thankful if someone could help me out :)
