how to interface . . . . ???
nasleh2
Dear All :
I have a question :
how can i make an interface
between a PIC16f877 with two servo motors ?
and
From where can i get a motor with torque
can load approximately 500 gram , with 70 rpm ?
PICs will drive servomotors directly. You need a program that will output a pulse about 0.5 - 1.5 ms long, every 20 ms. 0.5 ms will give one end of travel, 1.5 ms the other end.
The voltage levels output by a PIC running on 5V are just right to drive a servo.
Power for the servo is 5V and is left on all the time, not controlled by the PIC.
Isn't a Servo pulse typically 1.0 to 2.0 msecs long with a 1.5 msec pulse placing the Servo in the "middle" of its travel?
Yes, of course it is 1-2 msec. Also I'm not sure a R/C type servo is correct for what the OP was asking for as he specified a 70 rpm speed and unless a R/C servo is modified it will not turn continously.
There is a difference between a servo motor (one element of a servo system) and a R/C servo device (a self contained servo system).
Lefty
Yes, basically there's far too little information in the original question.
thanks to all,
but my quistion was about interfacing not programming.
How can i konw required elements such as resistors,inductors and capacitors needed?
and i know that i have to put Hbridge . . . . .
BUT HOW TO INTERFACE BETWEEN PIC AND MOTORS CIRCUITLY ?
