How to connect a temperature PID controller with an external relay
oliveros
Hi group,
I need to control a 12V 100W peltier, with a CAL3300 temperature controler (like the shown in **broken link removed**),
The internal relays from the CAL3300 supports only 2A, so I want to connect an external solid state relay (10A/28VDC DC 5V) the relay have 5 connectors, so could anybody teach me how to connect this relay with the CAL3300?.
In this link you can find a picture with an scheme shown in the CAL3300 and a picture of the relays.
It depends on the +5vdc input current requirement for the solid state relay. It it requires only 15ma or less you can wire the relay control input pins to pins 3 & 4 of the controller. You may have to enable the SSR drive output in the controller's setup and that information should be in the controller's documentation.
Lefty
dear Leftyretro., thanks for your answer.
I am not sure abour the current requirements of the relay, do you know where I could find this information?. Concernig to the relay wiring, it have 5 connectors, I do not know who are the control inputs.
Thanks for your support!
Lefty
Well you are going to have to search for the data sheet for the solid state relay, it will have the contact information and coil drive requirements.
Lefty
This is not a solid state relay, it's a standard electromechanical SPDT relay.
https://www.techman-usa.com/info/118.pdf Relay pin layout: third row down on the right.
But, that should work fine for you.
Wiring looking at the bottom of the relay (as shown on 118.pdf):
+5v power supply to pin-6 on the controller.
Left end of the relay coil to pin 5 on the controller.
Right end of the relay coil to 5v power supply common.
Peltier power supply (+) to bottom-center pin on the relay.
Peltier cell (+) lead to upper-left pin on the relay.
Peltier cell (-) lead to Peltier power supply common.
Ken
