Welcome to our site! Electro Tech is an online community (with over 170,000 members) who enjoy talking about and building electronic circuits, projects and gadgets. To participate you need to register. Registration is free. Click here to register now.
Could any one help me, How to calculate the reg. value to achieve a desired delay in 8051 micro controller. Suppose I need 250ms delay .What should be the reg. value ,I have to take.
For HERE loop, we have (4x250)x1.085μs=1085μs. For AGAIN loop repeats HERE loop 200 times, so we have 200x1085μs=217000μs. But “MOV R3,#250” and “DJNZ R2,AGAIN” at the start and end of the AGAIN loop add (3x200x1.805)=651μs. As a result we have 217000+651=217651μs.
from the The 8051 Microcontroller and Embedded Systems Using Assembly and C-2nd-ed
Very helpful for me
I should also add that was assuming one machine cycle lasts 12 oscillator periods like the AT89C51 and also using a 11.0592 MHz crystal
11.0592/12 = 921.6 kHz;
machine cycle is 1/921.6 kHz = 1.085μs
If a memory chip of size 256 kilobytes (256 x 1024 x 8 bits),
how many wires does the address bus need, in order to be able to specify an address in
this memory?
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
