How to build a radiocontrolled switch.
Lac
Ok, I want to build a radiocontrolled switch, easy, or?
I know I need a transmitter and a receiver. I have been searching around a bit for radio transmitters and recievers, but all of them seems too complicated for what i need. All i want is a simple transmitter, with a switch to trigger it and send a signal to the receiver, which controls a relay, and turns the ligt on and off.
As long as the receiver receives a signal it holds the relay in the "on" position, and when it doesn't receives a signal anymore, the relays turns off.
Hope you guys understand me. :wink:
Cheers!
Lac.
hi
it may be cheaper and easier to use something premade..
I have used a wireless doorbell for something similar, in my case it was to operate a solenoid that controlled a water supply. the door bell circuit was perfect since it only triggered the output while the remote button was pressed.
best part... it cost only about $20 US
hope this helps
heres a link:
likely there is something similar in your country.
