how to activate interupt 1 and 2 on a 18f2550
pe1riv
Hi all,
Got a problem how to get the interups 1 and 2 working.
Interupt 0 is working fine with the demo.
But i need more interupts how to do that ?
this code is what i use now for testing the interups:
Dim x As Byte
x = 255
TRISA = 0
PORTA = x
INTCON.INT0IE = 1
Enable High
End
On High Interrupt
x = x - 1
PORTA = x
INTCON.INT0IF = 0
Resume
if I change INTCON.INT0IE to INTCON.INT1IE (checkt the 0 or the 1) it will licht up blue but if I compile it gives an error "constant argument can not be used here"
I need 2 interupts for my project the 2550 has 3 (0,1,2) > pin 21,22,23
Can someone help me out ?
The two interrupt flags for INT1 and INT2 are in INTCON3 register
So set the interrupt bits 4 and 3
INTCON3.INT2IE
INTCON3.INT1IE
Flags are bit 1 and 0
INTCON3.INT2IF
INTCON3.INT1IF
You can also set the priority High or Low
tnx for the fast reply....
tried it out and it works perfect.
These are the things I'm missing in the manual....
