How is ATTINY-13 programmed ?
potoole64
How is the ATTINY-13 programmed? Or the ATTINY-26?
Can one use the same method as for the ATMEGA32?
My ATMEGA32 is set up to use the STK200/300 programmer using a 10 pin ISP cable and connector, does this mean that any other microcontrollers that can be programmed with this set-up must have the same number of pins?
Would the ATTINY's require a different programming set-up?
Thank you
Patrick
Most avr's are programmed in ISP mode. This means that with only 4 wires you can program the device in circuit. Another method for programming is he parallel method which involves more wires, and cannot be done in circuit. There are other methods for more sophisticated avr's but for most of them there are the two methods mentioned above.
In ISP programming mode, you must be careful when programming the clock select fuse. If programmed incorrectly, you will need to use a parallel programmer to restore the clock fuse.
You should read the datasheet for the device you are using, it is explained very well.
There are lots of programs that will work for your board. but mainly I stick with avrstudio to do the programming.
YES,
as long as you match the MOSI, MISO, SCK and RST pins. Be sure you supply a clock source to the device being programmed. (and as long as your software supports this device)
Thank you
Patrick
Not all microcontrollers use the SPI pins for ISP programming.
Only the microcontrollers that use the same pin configuration can be programmed with this type of setup. One example is the 8051 based Atmel 89S2051. It has the same programming pins as the attiny2313 except the reset would be inverted - If there is a pullup on the reset pin on your board you must remove it. And of course, the software would have to support this device.
Good Luck
