Welcome to our site! Electro Tech is an online community (with over 170,000 members) who enjoy talking about and building electronic circuits, projects and gadgets. To participate you need to register. Registration is free. Click here to register now.
Hi
I want to send the pulses of optic counter via a 24v dc or 32 v ac power line.
how it is possible? I am waiting for your help.
thanks.
it is from a robot movement.
I Find You Are Perfect In Robotic Systems.i Want To Deacreas The Number Of Wires.back Of My Robot Is The Power Cabel.and I Want Send The Movement Inf From Robot Via This Power Line.
Thanks.
Is it really possible? IMHO, the only time you can send pulses over AC line is when it is near its zero crossing because it is the time when the voltage low enough that shorting wouldn't produce too much current that could damage the transistor producing the pulses
Thanks.
You can send pulses down any power line by injecting the line with the pulses
using a carrier frequency and then at the receive end reconstruct with a
detector. This is similar to how radio works. Your transmitter sends the
signal, your receiver detector changes the info back to its regular form.
The only trick is you have to use a frequency that is much higher than the
line frequency so that you can easily filter out the line and keep the signal,
which is very much smaller than the line amplitude.
You might also have to use special transmit codes that keep the average
dc level to zero.
For example, say you use a carrier of 200kHz. You would couple this to the
line with a high pass filter. At the receive end, you would have a filter that
has a center frequency of 200kHz, which would filter out everything but
the 200kHz carrier. You would then use a detector to detect the modulated
control pulses and then a microcontroller to convert them back into the
required one's and zero's for the logic.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
