How do I remove the ripple from my bridge rectifier
ed sparks
How do i figure out what size(s) capacitor(s) I need for my ac to dc rectifier crcuit in order to eliminate the ripple.
Gene
Did you really mean 'eliminate' or did you mean reduce? If you meant eliminate, that's fine. I was just thinking that capacitor prices seem to increase with capacitance. If your application dosen't need 0 ripple, you may be able to save a little money by keeping a sight ripple.
stevez
Active Member
Some voltage regulators behave in a way that reduces ripple. I get the impression that careful design of even a simple power supply can result in an output that has low ripple. I've seen the ripple reduction specs that are used to decribe the common regulator ICs but I don't have the skills to interpret what I read, at this point anyway. I might be correct in concluding that the ripple reduction features of some IC's might reduce the demands of a filter capacitor. As suggested, the price of large caps is up there - many ICs and associated electronics are cheap.
