how create menu and sub menu in pic
List the items you want... Also what display have you got!
My menu works on a 16x2LCD and I only use 4 buttons
MENU, ENTER, UP and DOWN..
I use 1 function per menuitem.... But remember your stack!! Depending on the chip you usually get a stack of 255 bytes ( It can be made bigger ). Use global structures for your menu's.
The thing with menus is they often become extremely nested... So each functions "local" variables must be stored somewhere....
Topology
MAIN MENU
....MENU 1
...........MENU 1 item 1
...........MENU 1 item 2
...........MENU 1 item 3
....MENU 2
...........MENU 2 item 1
...........MENU 2 item 2
...........MENU 2 item 3
etc....
I posted some basic menu code here. It's in BoostC but should give you a general idea.
Void init_peripheral();
Void Referesh();
void setRelay();
void display();
#bit sel1 =0x07.7
#bit sel2 =0x07.6
#bit sel3 =0x07.5
#bit sel4 =0x07.4
#byte portb=0x06
#bit menu =0x07.0
#bit up = 0x07.1
#bit down =0x05.1
#bit enter =0x7.3
#bit relay1=0x05.4
#byte trisb=0x86
#byte trisa=0x85
#byte trisc =0x87
#byte portc =0x07
//#define step_size=0.01640625
float digital_data;
int16 count,digital,value;
int8 i;
int8 A2=0;
const int8 seg[10]={0x7e,0x0c,0xb6,0x9e,0xcc,0xda,0xfa,0x0e,0xfe,0xce};
void display()
setup_adc_ports( AN0 );
set_adc_channel(0);
delay_ms(1);
//this calcultion for getting voltage level.
//count=(read_adc()/51.00)*100;
count=read_adc();
if(count<20)
portb=0x80;sel4=1;delay_ms(1);sel4=0;
portb=0x80;sel3=1;delay_ms(1);sel3=0;
portb=0x80;sel2=1;delay_ms(1);sel2=0;
portb=0x80;sel1=1;delay_ms(1);sel1=0;
digital=0;
else if((count>=21)&&(count<=75))
digital=0;
referesh();
else if((count>=76)&&(count<=80))
digital=(1+((count-76)*0.5));
referesh();
else if((count>=81)&&(count<=96))
digital=(3+((count-81)*0.266));
referesh();
else if((count>=97)&&(count<=112))
digital=(7+((count-97)*0.333));
referesh();
else if((count>=113)&&(count<=117))
digital=(12+((count-113)*0.75));
referesh();
else if((count>=118)&&(count<=164))
digital=(15+((count-118)*0.217));
referesh();
else if ((count>=165)&&(count<=252))
digital=(25+((count-165)*4.31));
referesh();
else if(count>=253)
digital=400;
referesh();
void main(void)
//setup_adc_ports( ALL_ANALOG );
setup_adc(Adc_clock_DIV_64);
//setup_psp(PSP_DISABLED);
setup_spi(SPI_SS_DISABLED);
setup_timer_0(RTCC_INTERNAL|RTCC_DIV_1);
setup_timer_1(T1_DISABLED);
setup_timer_2(T2_DISABLED,0,1);
setup_comparator(NC_NC_NC_NC);
setup_vref(FALSE);
enable_interrupts(int_timer1);
enable_interrupts(global);
init_peripheral();
count=0;
while(1)
display();
void init_peripheral()
trisa=0x0f;trisb=0;digital_data=0;
trisb=0;trisc=0x0b;
void referesh()
int16 d1,d2,d3,d4;
d3=(digital%10); //third digit
d2=(digital/10)%10;//second digit
d1= digital/100; //first disgit
portb=seg[d3];sel4=1;delay_ms(1);sel4=0; //display first digit
portb=0x01;sel2=1;delay_ms(1);sel2=0; //dispaly decimal point
portb=seg[d2];sel3=1;delay_ms(1);sel3=0; //display second digit
portb=seg[d1];sel2=1;delay_ms(1);sel2=0; //display third digit
this is my code and i want to set a relay point
if i press menu it will go to 'set' and if i press enter then it will go to set value 0.00 to 4.00
adc out is 0.00 to 4.00 to seven segment disp
