how a 12vdc small water pump (found in car) operate?
panjangsangat
can someone tell me how a 12vdc small water pump which use in a car to water the front car window through nozel operate? If can, can someone provide me the diagram or flow chart?
It operates with a switch that puts 12 V on the 12 v motor/pump. FFS WHAT sort of question is that?
I know on a Nissan it is linked to the controls (levers) on a the steering wheel through a Relay.
The longer you activate said control.....the longer the water will flow and hence the cleaner your windscreen will be.
I don't believe you will find a diagram or flow chart. Just way too basic.
Yes, perhaps the pump is operating in reverse?
