Home Light
SeanHatch
I was wondering what would be the best ohmage of a pot used as a dimmer switch to a house light. This light is actually composed of 2 standard light bulbs, also how would you hook this up properly.
Thanks.
Sean
You don't want to use a pot as a dimmer; the dissipation would be outrageous. Research using triacs instead. BTW it would be much cheaper and safer just to buy one, unless you are doing this just for the exercise of it.
j.
A triac is like an SCR, but conducts on both positive and negative AC half-cycles.
So, what's an SCR, I hear you ask... An SCR is a 3 terminal device. The terminals are called Anode, Cathode and Gate. The basic idea is that SCR will conduct current from the Anode to the Cathode, BUT only after a trigger signal is applied to the gate. It will keep conducting after you remove the gate signal, so the only way to turn it off is to 1) remove the source of current, or 2) short out the anode and cathode.
A triac behaves like 2 SCRs back-to-back. The terminals are not anode and cathode, but instead, are called Main Terminal 1 (MT1) and Main Terminal 2 (MT2).
Now, think about about the AC cycle. What happens at the end of every half-cycle? The voltage drops to zero, right? Therefore the current drops to zero, and the triac switches off. SO... to keep a triac in conduction, you have to keep triggering it every half-cycle.
There are lots of pre-cooked dimmer circuits around, using a triac. Here is one:
https://www.aaroncake.net/circuits/dimmer.htm
Good luck!
Your post sounds a bit like you want a light dimmer using only a pot. DON'T DO IT - normally available pots are not made to handle this application and you could easily be hurt. Use Phasor's circuit if you are wanting to learn something about electronics.
