Hello,
We are wanting to do high frequency PWM dimming of the output of Resonant Inductive Couplers (which feed LED lamps) hooked up to a twisted pair bus.
Do you think the “gap toothy” resulting waveform (see below) will be a cause of any problems?
(This is a different question on a subject discussed elsewhere here, needing a new thread due to new diagramatic info here)
Block diagram………………..
https://i46.tinypic.com/28151kz.jpg
….you can see the “shorting FETs which dim by stopping current flowing to the LEDs when the FETs are ON.
(-please ignore the number of secondary turns....as you know, there is a resonant coupling method)
We do NOT want to do low frequency PWM dimming, (~200Hz) because the low frequency of this dimming causes problems for the current source. (-it means the current source is switching from high power to low power output which causes problems)
Therefore, we wish to do dimming at a much higher frequency (83.3KHz). But do you think that the resulting current waveform (as below, when D is not equal to 1) is going to mean problems?
LED lamp current with no dimming (D = 1)
https://i47.tinypic.com/o9iv.jpg
LED lamp current with dimming with D = 0.083
https://i48.tinypic.com/3ctas.jpg
LED lamp current with dimming with D = 0.33
https://i50.tinypic.com/1zofdzp.jpg
LED lamp current with dimming with D = 0.92
https://i49.tinypic.com/np5d91.jpg
(Also, how would you reduce dissipation in the current source by correcting the power factor in the twisted pair?)
Resonant inductive coupling…………
https://en.wikipedia.org/wiki/Resonant_inductive_coupling
