One of my issues, I will now check, is upping the Zener resistor will screw up my RDon
All explained now
Anyhow, the zener shouldn't mess anything up, it's simply to prevent too high voltage between source and gate. If you're using a zener, then there's no need to worry about calculating the respective values of the two resistors - and all you need for the top one is a high value resistor to bleed any charge away. So you can ignore the top resistor, and simply calculate the bottom resistor based on the current you want through the zener.
