help!!!
qyc88
could anyone help me create a timing circuit which:
.... has a capability of timing from 30 minutes to 2hours
.... using two 555 ic to create one ic for the main timing and the other for changing the time a LED stays working for and pulse speed of it
thanx :) [/img]
It is hard to get any kind of accuracy for long periods
using only timer chip. I would recommend using counter(s) to
achive long times. Check the datasheet for 4020
It's 14-bit counter (divide by 16384).
Half an hour is 30*60=1800 seconds (16384/1800=9.1Hz).
Two hours is 2*60*60=7200 seconds (16384/7200=2.2Hz).
So all it takes is to make adjustable oscillator that would cover
range 2-10Hz (maybe flash LED as well so you can easy tell the
difference).
timer
:D
you can also try CD4536 and you can also use the site cited by panic mode :D :D
