Help with writing to a port
I've got a problem with this code not writing to porta if mplab sim. I'm having similer problems elsewhere in the code but this is my power on routine to see that everything is working but it is not. Am I using the #define correctly? I also tried to use the set directive in a previous version but it did not work correctly either. Please, help!:o
	list		p=16f870	; list directive to define processor
	#include	<p16f870.inc>	; processor specific variable definitions
	__CONFIG _CP_OFF & _WDT_OFF & _BODEN_ON & _PWRTE_ON & _XT_OSC & _WRT_ENABLE_OFF & _LVP_OFF & _CPD_OFF
; '__CONFIG' directive is used to embed configuration data within .asm file.
; The lables following the directive are located in the respective .inc file.
; See respective data sheet for additional information on configuration word.
;***** VARIABLE DEFINITIONS
w_temp		EQU			0x7E		; variable used for context saving
status_temp	EQU			0x7F		; variable used for context saving
#define		tps			porta,0
#define		tach		porta,2
#define		led			porta,4
#define		up			portb,1
#define		down		portb,2
#define		bypin		portb,3
#define		rangein		portb,5
#define		bypass		portc,4,5,6,7
#define		ledflg		atemp,5
#define		outputc		portc
#define		firstflg	shftflg,0
#define		secondflg	shftflg,1
#define		thirdflg	shftflg,2
#define		fourthflg	shftflg,3
			udata_shr
atemp		res			1			;porta temp
swtemp		res			1			;switch temp
output		res			1			;portc
count0		res			1			;for delay
count1		res			1			;for delay
count2		res			1			;for delay
shftflg		res			1			;flag byte for gear position
first 		res			1
second 		res			1
third		res 	             	1
fourth		res			1
	ORG     0x000             ; processor reset vector
main		bsf			status,5			;bank 0
			movlw		d'5'
			movwf		trisa				;
			movlw		d'255'
			movwf		trisb
			movlw		d'0'
			movwf		trisc
			movlw		b'00001010'
			movwf		adcon1
			bcf			status,5
			clrf		porta
			clrf		portb
			clrf		portc
			movlw		b'01000000'			;setup for ch0 but not on
			movwf		adcon0				;
			clrf		porta
			clrf		portb
			clrf 		portc
			clrf		atemp
			clrf		shftflg
			clrw
			bsf			ledflg
			movfw		atemp
			movwf		porta
			call		delay
			clrf		porta
			call		delay
			movfw		atemp
			movwf		porta
			call		delay
			nop
			call		delay
			clrf		porta
			movlw		d'243'
			movwf		first
			movlw		d'241'
			movwf		second
			movlw		d'240'
			movwf		third
			movlw		d'242'
			movwf		fourth
end
You set bit 5 of atemp and write atemp to porta but your code suggests your LED is on bit 4. Can i suggest that you tidy up your code, it's very hard to follow as you have lots of repeated stuff.
