Help with receiving a byte on an i2c bus..
Steve311
Hi All; I am trying to receive a byte on an i2c bus using a pic16f684. I am receiving the 3 required ACK's from the slave, then when I try to read the data bits (and I can see on an oscope), that the DATA line stays high during all of the clock pulses that the pic provides. I am trying to read a register that should return 0x55 so I know this is definately wrong. The output of the project is to a hyperterminal. This part of the code I know works I have used it man times before and have tested it in this application.
Any help is greatly appreciated,
Steve
;Call proper header, include and source files to initialize PIC
 	LIST  		p=16F684    ; Tells Assembler what PIC is used
 	#INCLUDE	<p16f684.inc>    ; Includes factory defaults for the PIC
;Configure PIC optional properties
 __CONFIG     _WDT_OFF & _MCLRE_OFF ; Enables CLKOUT, WDT, and Digital I/O on MCLR/RA3
 ;errorlevel -302, -207, -305
;Define Constant Working Register Variables
	cblock 0x20
	i2c_transmit_byte
	i2c_bit_counter
	pw_counter
	pw_counter1
	wait_startup_counter
	Received_I2C_Byte
	transmit_byte_rs232
	bit_counter_rs232
	delay_counter
	osc_counter
	endc
;Define Global Deifnitions:
I2C_PORT	equ		PORTC
I2C_TRIS	equ		TRISC
#define		SDA	 	2
#define		SCL 	3
START_PROGRAM
;Initialize Inputs/Outputs, and Registers on the PIC16F684.
;Initialize TRISA and TRISB registers.
 	bsf 	STATUS, RP0			;Bank 1
 	movlw 	b'00001100'
 	movwf 	TRISC				;Assigns SDA and SCL Inputs.
 	movlw	b'00000000'
	movwf	TRISA				;Assigns all TRISA as outputs.
	movlw	0x03
	movwf	OSCCON				;Loads internal 31.25kHz clock
	bcf		STATUS, RP0			;Bank 0
	clrf	CCP1CON
	call	Sleep_Routine
;READ Register from Kionix KXTJ9 accelerometer -- DCST_RESP Register located at 0x0C
;BusFixed
	call	Clock_Pulse_Delay
	call	Clock_Pulse_Delay	;Startup Delay
;	call	Transmit_RS232
	bcf		PORTC, 0
	call	Start_Command		;Start Command
	call	SAD_W				;Address Slave plus write
	call	ACK					;Get Acknowledge from slave
	call	Who_Am_I_Reg
	call	ACK
	call	Start_Command
	call	SAD_R
	call	ACK					;Successful ACK received up to this point
	call	Receive_i2c_Byte
	call	Transmit_RS232
	call	NACK
	call	Stop_Command
done
	bsf		PORTC, 0
	goto	done
	goto	START_PROGRAM
;Sub Routines for PIC
;i2c Routines
Start_Command
	call	Set_SCL_High				;Release SCL
	call	Set_SDA_High				;Release SDA
	call	Clock_Pulse_Delay			;Delay
	call	Set_SDA_Low					;Set SDA Low
	return
SAD_W
	movlw	0x1E
	call	Send_i2c_Byte				;(SAD+W)Slave Address plus write.
	return
SAD_R
	movlw	0x1F
	call	Send_i2c_Byte				;(SAD+R)Slave Address plus read.
	return
ACK
Clock_Stretch
	btfss	I2C_PORT, SCL
	goto	Clock_Stretch				;Wait for slave to release clock line (if "stretching")
	bcf		STATUS, C					;Initally clears the carry bit
	btfsc	I2C_PORT, SDA				;Checks if slave is pulling SDA low (giving its ACK)
	goto	_Error						;Clear carry for NACK
	bsf		STATUS, C					;Set carry for ACK
	btfss	STATUS, C					;Check carry bit to ensure ACK
	goto	START_PROGRAM				;Start over if NACK
	return								;If ACK received, continue
NACK
	call	Set_SCL_Low					;Set SCL Low
	return
Stop_Command
	return
Send_i2c_Byte
	movwf	i2c_transmit_byte			;Moves whatever value is in the working register into i2c_transmit_byte
	movlw	0x08
	movwf	i2c_bit_counter				;Sets 8 bits to be sent out
Send_i2c_Bit
	call	Set_SCL_Low					;Ensure SCL is low initially
	rlf		i2c_transmit_byte, f		;MSB is now in carry (MSB is sent first)
	btfsc	STATUS, C
	call	Set_SDA_High
	btfss	STATUS, C
	call	Set_SDA_Low					;Sets either 0 or 1 to be sent out. (Checks carry bit)
	call	Set_SCL_High				;Trigger Clock; set SCL high
	decfsz	i2c_bit_counter, f			;Checks if 8 bits have been sent out
	goto	Send_i2c_Bit				;No
	call	Set_SCL_Low					;Yes; Set SCL Low
	return
Receive_i2c_Byte
	clrf	Received_I2C_Byte			;Clears previous received byte
	bsf		Received_I2C_Byte, 0
Get_i2c_Bit
	call	Set_SCL_Low
	call	Set_SDA_High				;Set SCL Low
	bcf		STATUS, C					;Defaults to incoming bit = 0 (sets carry = 0)
	btfsc	I2C_PORT, SDA				;Read port, skip if clear
	bsf		STATUS, C					;If incoming bit = 1, set carry flag to 1
	rlf		Received_I2C_Byte, f		;move carry into data (MSB first)
	btfss	STATUS, C
	goto	Get_i2c_Bit					;No
;Test to ensure hypertermianl works correctly.
;	movlw	0x55
;	movwf	Received_I2C_Byte
	call	Set_SCL_Low
	movf	Received_I2C_Byte, w		;Moves result to the working register
	return								;Yes, return
;Routines to Set SDA and SCL High/Low
Set_SCL_High
	bsf		I2C_TRIS, SCL			;Sets SCL as an input
	clrf	ANSEL
	movlw	0x07
	movwf	CMCON0
	return
Set_SCL_Low
	bcf		I2C_PORT, SCL			;Sets SCL port pin low
	bcf		I2C_TRIS, SCL			;Sets SCL as an output
	clrf	ANSEL
	movlw	0x07
	movwf	CMCON0
	return
Set_SDA_High
	bsf		I2C_TRIS, SDA			;Sets SDA as an input (high impedance)
	clrf	ANSEL
	movlw	0x07
	movwf	CMCON0
	return
Set_SDA_Low
	bcf		I2C_PORT, SDA			;Sets SDA port pin low
	bcf		I2C_TRIS, SDA			;Sets SDA as an output
	clrf	ANSEL
	movlw	0x07
	movwf	CMCON0
	return
;Delays
Clock_Pulse_Delay
	movlw	0xFF
	movwf	pw_counter
Clock_Pulse_Delay_Wait
	nop
	movlw	0x01
	movwf	pw_counter1
Clock_Pulse_Delay_Wait1
	decfsz	pw_counter1, f
	goto	Clock_Pulse_Delay_Wait1
	decfsz	pw_counter, f
	return
bit_delay
	movlw	0x16
	movwf	delay_counter
bit_wait
	nop
	decfsz  delay_counter, f
	goto	bit_wait
	return
Osc_Stablize
	movlw	0xFF
	movwf	osc_counter
Osc_Wait
	nop
	nop
	nop
	decfsz	osc_counter, f
	goto	Osc_Wait
	return
I2cInit
	call	Set_SCL_Low
	call	Set_SDA_Low
	call	Set_SCL_High
	call	Set_SDA_High
ClockLoop
	btfsc	PORTC,SDA
;	goto	BusFixed
	bcf		PORTC,SCL
	bsf		STATUS,RP0
	bcf		TRISC,SCL
	goto	$+1
	bsf		TRISC,SCL
	bcf		STATUS,RP0
	goto	ClockLoop
Who_Am_I_Reg
	movlw	0x0C  ; - Substitute for DSCT_RESP
	call	Send_i2c_Byte
	return
;Sub routines for PIC to Hyperterminal
;****SENDS INVERSE LOGIC TO PROLIFIC RS-232 TO USE CONVERTER
Transmit_RS232
	movwf	transmit_byte_rs232		;moves W to transmit_byte
	bsf		STATUS, RP0
	movlw	0x65
	movwf	OSCCON
	movlw	0x00
	movwf	TRISC
	movlw	0x00
	movwf	TRISA
	bcf		STATUS, RP0
;	movwf	transmit_byte_rs232		;moves W to transmit_byte
	call	Osc_Stablize
;	movlw	0x55
	bcf		PORTC, 5
;	movlw	0x55
;	movf	Received_I2C_Byte, w
	movlw	0x08
	movwf	bit_counter_rs232		;sets 8 bits to send out
	bsf		PORTC, 5
	call	bit_delay
Send_Serial_Loop_RS232
	rrf		transmit_byte_rs232, f		;Send one bit
	btfss 	STATUS,	 C
	bsf		PORTC, 5
	btfsc	STATUS,  C
	bcf		PORTC, 5
	call	bit_delay
	decfsz	bit_counter_rs232, f		;Tests if all done
	goto	Send_Serial_Loop_RS232
	bcf		PORTC, 5
	call	bit_delay
	call	bit_delay
	bsf		STATUS, RP0
	movlw	0x03
	movwf	OSCCON
;	movlw	0x00
;	movwf	TRISC
;	movlw	0x00
;	movwf	TRISA
	bcf		STATUS, RP0
	return
_Error
	movlw	0x45
	call	Transmit_RS232
	movlw	0x52
	call	Transmit_RS232
	movlw	0x52
	call	Transmit_RS232
	movlw	0x4F
	call	Transmit_RS232
	movlw	0x52
	call	Transmit_RS232
	goto	START_PROGRAM
Sleep_Routine
	movlw	0x07
	movwf	WDTCON
	sleep
	movlw	0x00
	movwf	WDTCON
	return
	end
I just checked your receive against mine and I see you are pulling the clock line low after receiving the byte. This will cause spurious clock pulses and prevent you from receiving an ACK. I see you're also doing the same in the send routine. I suspect these spurious clock pulses are getting the master/slave out of sync and causing your problem.
BTW, you only need to set ANSEL and CMCON0 once at the beginning of your program.
When I don't set the clock line low at that point in the send routine, the slave does not ACK. When I set the clock low there it does ACK... I'm a little confused.
What other than spurs can get the communication out of sync?
I hooked up a 24LC16 to a 16F886 and got it half working with your code. I'll have another go at weekend and hopefully get it working.
  • Like
Reactions: 3v0
Oh Great! I have some of those too...
Where did you get it to half way working? Or Rather, where does it stop working?
I got it writing 0x45 to address 0 and noted the NACK whilst the write took place but it failed to read back properly. I get acknowledges on all writes and a delay before more acknowledges on the read back but the value is 0xff. I'll have another try over weekend, probably not until Sunday.
Very interesting Mike, That is EXACTLY what I am experiencing too. All data that I'm receiving is 0xff which is wrong. I will have time for it this weekend myself.
Steve
I managed to finally get it working.
These are the I2C routines,
;i2c Routines
Start_Command
		return
Stop_Command
		call	Set_SCL_Low
		call	Set_SDA_Low
		call	Set_SCL_High
		call	Set_SDA_High
		return
GetACK
		call	Set_SCL_Low
		call	Set_SDA_High
		call	Set_SCL_High
Clock_Stretch
		btfss	I2C_PORT, SCL
		bcf	STATUS,C	;Initally clears the carry bit
		btfss	I2C_PORT,SDA	;Checks if slave is pulling SDA low (giving its ACK)
		bsf	STATUS,C	;Set carry for ACK
SendNACK
		call	Set_SCL_Low
		call	Set_SDA_High
		call	Set_SCL_High
		return
Send_i2c_Byte
		movlw	0x08
Send_i2c_Bit	call	Set_SCL_Low	;Ensure SCL is low initially
		btfsc	STATUS, C
		call	Set_SDA_High
		btfss	STATUS, C
		return
Receive_i2c_Byte
Get_i2c_Bit	call	Set_SCL_Low
		call	Set_SDA_High
		bcf	STATUS,C	;Defaults to incoming bit = 0 (sets carry = 0)
		btfsc	I2C_PORT,SDA	;Read port, skip if clear
		bsf	STATUS,C	;If incoming bit = 1, set carry flag to 1
		btfss	STATUS, C
		return			;Yes, return
Set_SCL_High
		bsf	STATUS,RP0	;Bank 1
		bsf	I2C_TRIS,SCL	;Sets SCL as an input
		bcf	STATUS,RP0	;Bank 0
		return
Set_SCL_Low
		bcf	I2C_PORT,SCL	;Sets SCL port pin low
		bcf	I2C_TRIS,SCL	;Sets SCL as an output
		return
Set_SDA_High
		bsf	I2C_TRIS,SDA	;Sets SDA as an input (high impedance)
		return
Set_SDA_Low
		bcf	I2C_PORT,SDA	;Sets SDA port pin low
		bcf	I2C_TRIS,SDA	;Sets SDA as an output
		return
I2cInit
		call	Set_SCL_High
		call	Set_SDA_High
ClockLoop
		btfsc	PORTC,SDA
		return
		call	Set_SCL_High	;Set SCL Low
		goto	ClockLoop
;Delays
Clock_Pulse_Delay
		goto	$+1
		goto	$+1
		goto	$+1
		goto	$+1
		goto	$+1
		goto	$+1
		goto	$+1
		goto	$+1
		goto	$+1
		goto	$+1
		goto	$+1
		goto	$+1
		return
And this is what I had to do to write and then read back a byte.
		movlw	0xa0
		call	Send_i2c_Byte	;send ID and Write
		call	GetACK
		btfss	STATUS,C
		goto	$-1
		movlw	0x00		;address 0
		call	Send_i2c_Byte
		call	GetACK
		btfss	STATUS,C
		goto	$-1
		movlw	0x56		;data to write
		call	Send_i2c_Byte
		call	GetACK
		btfss	STATUS,C
		goto	$-1
		call	Stop_Command
again		call	Start_Command	;Start Command
		movlw	0xa0
		call	Send_i2c_Byte
		call	GetACK
		btfss	STATUS,C
		goto	again
		call	Send_i2c_Byte
		call	GetACK
		btfss	STATUS,C
		goto	$-1
		call	Stop_Command   ;doesn't work without this command
		call	Start_Command
		movlw	0xa1
		call	Send_i2c_Byte
		call	GetACK
		btfss	STATUS,C
		goto	$-1
		call	SendNACK
		call	Stop_Command
		movfw	Received_I2C_Byte
hang	goto	hang
The thing that was stopping it working was the lack of the stop command in the read back part.
